Best oils, lubricants?
Old Mar 22, 2007 | 11:20 PM
WA2GOOD's Avatar
WA2GOOD
Originally Posted by Resolute
I've got about 30 or so UOA's on VQ engines with a bunch of oil brands. M1 still outperforms most, especially for the price. I think people will be a little shocked by the Amsoil results in comparison. Should have them all posted in the next day or so when I'm done transferring them all to jpg and can post them here.
Will
Thanks, I would love to see that.
Old Mar 23, 2007 | 08:20 AM
Peak350's Avatar
Peak350
Cropped from the 2007 owners manual, GL-4 for MTL, and GL-5 80w-90 for the diff.
Old Mar 23, 2007 | 08:24 AM
FORZWIN's Avatar
FORZWIN
Just remember K&N filters = M1 filters. Both made by Champion Labs with the same casing, filter, drain back valve diaphram... on the same assembly line. You pay a hair more for the K&N's 1" tack welded nut and white paint.
I was not aware of that, thank you.
Old Mar 23, 2007 | 09:01 AM
Peak350's Avatar
Peak350
Originally Posted by farobaba
anything but mobil1
I've been trying to compare the conventional oils, Quaker state appears to be crap from what they DON'T list online.
Shell Rotella, I'm undecided on, and Pennzoil I'm gonna give the thumsdown to.
Mobil 1 conventional looks good, but have heard issues - Castrol GTX is allright, thats my other real option.
What is the factory fill oil?
I will switch eventually to a synthetic (probably a blend after the first couple changes either way). But I'm doing a 1,200 mile flush and a 3,750 change (dealer covered), so I figure those should at least be on the same oil (so I can actually get it analyzed.
edit - and this ruined my day, time to not drive my car the same (only has 120 miles or so, thankfully):
Owners Manual break-in procedure.
 Avoid driving for long periods at constant
speed, either fast or slow. Do not run the
engine over 4,000 rpm.
 Do not accelerate at full throttle in any gear.
 Avoid quick starts.
 Avoid hard braking as much as possible.
 Do not tow a trailer for the first 500 miles
(800 km).
Old Mar 23, 2007 | 12:31 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I think there is more than enough info already on this subject, please search and / or read the top 100 questions thread.
Old Mar 23, 2007 | 03:01 PM
DRIFTU's Avatar
DRIFTU
thank you all for the advice and different opinions, i have no idea what to choose now haha. I did notice the other threads after posting this one... im gonna try to see if i can do a poll on this so we get more accurate results..
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
