Any way to avoid aftermarket pulley squeal?
Old 04-04-2007, 12:13 PM
DanielW
DanielW's Avatar
awesome now trade me your z for mine
Old 04-04-2007, 12:39 PM
Wired 24/7
Dr. Wired
Wired 24/7's Avatar
I'd take it to someone who's experienced installing several pullies.
The belt changes elasticity when it's cold/warm. So sometimes it has to go through heat cycles, and I forget if you're supposed to tension it while it's cold or while it's warm... but a pro should know what to do.
(Basically if you tension it while it's cold, it could get looser when warm. If you tension it too much when it's warm, then it will be way too tight when it's cold)
Some people will say it's an easy job. Others will say it is damn near impossible. I suggest going to a pro.
Old 04-04-2007, 12:54 PM
NA&CH
NA&CH's Avatar
Mine was installed and is squealing a little bit. I need to get it tightend.. SOunds like a pinto when I take off from a light
Chris
KJR pulley. Its not the pulley. The belts are loose
Old 04-14-2007, 11:06 AM
DanielW
DanielW's Avatar
so does it start off gradual or is it just like all the sudden squealing like a **** one day?
07-10-2022 07:44 AM
Fixxxercask
11-09-2015 11:10 AM
350z82
10-01-2015 06:25 PM
samansharif
09-25-2015 12:31 PM
Quick Reply: Any way to avoid aftermarket pulley squeal?
