J-Spec NA build
Old Mar 27, 2007 | 05:46 PM
scratch137's Avatar
scratch137
Default J-Spec NA build
Ok so as most of the people going NA already know, its pretty damn near impossible to break 300whp w/o doing some SERIOUS engine work. But now in Japan, those tuners are already breaking that, and are going for 400whp!!!
My question to you all is simple. How the F* are they doing that. I looked into some of the builds on their cars, and it just doesnt make any sense. For example;
The Amuse Z, we all know this is a killer. Amuse claims they only did the following, and are achieveing ~300whp:
* Nismo Spec 2 Camshafts
* Nismo Spec 2 Heads
* Titanium Intake Tube
* Tuned ECU ROM
* Titanium Exhaust
* Titanium Front Pipe (includes headers and Test pipes)
* Titanium Y Pipe
I know titanium doesnt make a diff in horsepower, but only in wieght, so i know that cant be their secrete. The only other thing i can think of is either the "front pipe" which are basically long tube headers (why dont we use these?) and the Heads.
I dont have to much knowledge in heads, but i dont see how they can make that much horsepower off just these mods. Cams: 10-15, Intake tube 5?, Exhaust 8-14; Y-pipe included in exhaust HP, Front pipe, well headers and testpipes yield about 15ish? but i dont know seeing as to how i have never seen these used on a 350 on here, and then the heads, which much be giving about 15HP to get then up to 300ish area. The tune is what is making these numbers because w/o it, these mods wouldnt come near 300HP.
So somehow, they are getting some damn good numbers, and if you look at the designs of some of their products, you see they are the same design as products we use here, stateside.
Im just trying to figure out how they are making these numbers really, and through this, seeing what you guys think would be needed to achieve around 300HP like the Amuse. So post away at some of your suggestions, and correct me if im wrong (which i probably am im many areas). Also, if someone can lend some insight on about how much power heads can give because i was thinking about port and polishing my heads if they will give me a decent bit more power.
And for you guys to also juggle in your heads, Top Secrete is building a 400HP NA Z, and they already have a Z they claim makes around 320whp, w/ about the same mods as the Amuse (actually i think the same mods except the heads). I was looking on the TS website, and noticed headers were like 5000$ and just fell out of my chair haha. But they do have an individual throttle body kit that could make some serious power. Give some input on that, seeing as to how it is very common on most J-spec cars over there, and not here.
Sorry if this seems stupid, and like a rant, i just kinda have been thinking about this for a while, and now im at the point where i need everyone elses geniousnessity (sp? lol).
Thanks,
Dan
Old Mar 27, 2007 | 06:42 PM
chris'smax's Avatar
chris'smax
IIRC i don't remember seeing a dyno on here of someone having cams and ported heads on here w/ a dyno posted. It is deff not out of the realm of possibilty for them to hit 300whp w/ those mods. Hell most people here with a header back exhaust, manifold, reflash, and intake(tha major powa adda ) see close to 270whp. Now with higher duration cams and some head work and port matching of the lower intake manifold would more than likely accomplish this. I would also assume they are using a far superior engine management setup than the average joe who uses a technosquare ECU.
Also remember the nismo spec 2 cams are far more aggressive than the JWT cams and Nismo r-tune cams.
Old Mar 27, 2007 | 06:58 PM
rocks's Avatar
rocks
I will tell you thier secret. They arent using some hardcore expensive engine managment. They are using the stock ecu to control the variable cam timing and getting hp that way. Call technosquare they will tell you they can change your cam timing for more power.
Old Mar 28, 2007 | 09:58 AM
97supratt's Avatar
97supratt
Changing cam characteristics on the ecu is only used when you install cams, so he has to have aftermarket cams to get any gains.
Old Mar 29, 2007 | 12:35 PM
scratch137's Avatar
scratch137
Well about how much do you think the heads are giving them? I know i was talking to a friend today and he does headwork on his porshe, and has done headwork for his friends civics and 240s etc, and he said i can probably gain around 30 to the wheels from heads. He hasnt ever worked on 350z heads, but he said most likely, by cutting the heads down abit, and raising compression to around 11:1/12.1 i could get ~30whp. Does that sound about right? And does that sound about right for those nismo heads?
Old Mar 29, 2007 | 12:41 PM
Mantis77's Avatar
Mantis77
Here ya go...... Try these out.
http://www.cosworth.com/shop_item.php?productid=442
Combined with:
http://www.cosworth.com/shop_item.php?productid=465
Easy way to spend $12,000 on PARTS!
Old Mar 29, 2007 | 12:44 PM
plumpzz's Avatar
plumpzz
Head games can probably make better heads than the ones cosworth sells.
Old Mar 29, 2007 | 01:03 PM
Enron Exec's Avatar
Enron Exec
Basicly, making more power is all about getting more air into the combustion chamber. You can either force it in or you can allow the pistons to pull more in per stroke. Those heads probably also have a valvetrain for 8krpm operation.
Old Mar 29, 2007 | 02:20 PM
scratch137's Avatar
scratch137
With NA though, i thought you want to raise combustion? Wouldnt allowing more flow from the heads make for lower combustion, or am i looking at this the exact opposite. Im a "duh-du-duh" when it comes to heads.
Old Mar 29, 2007 | 03:05 PM
eat rice z33's Avatar
eat rice z33
The JDM tuners dont only focus on slapping **** on the engine and doing ricer math. it involves complex dynamics between different parts. Tuners like TOMEI for example have ridiculous RandD. They make there headers while having the engine on an engine dyno. Who in america does that? crawford? dc? exactly. Plus the ecu tuning in japan far exceeds anything a UTEC can do. They simply use engineers to design there engine parts. not your typical american engine builder who has little if any background in engineering which does not allow them to understand statics, thermodynamics, and complex mathematics that are involved in engine building. I only have some understanding of the mathermatics of an internal combustion engine because my friends are mechanical/chemical engineers. i am an electrical engineer student. But i know enough to speak my mind.
Old Mar 29, 2007 | 03:14 PM
scratch137's Avatar
scratch137
Ok well a few things i was wondering from some of these responces;
1) What is the Headgames website lol
2) Where can i find Nismo Spec2 heads
3) If i where to port & polish my heads locally by a professional, would it be safe to assume the same gains as a nismo headkit or a headgames kit etc? Or is there more to those kits then just Port n polish? What i mean i guess is, can i do what those kits do w/ just port and polishing?
And idk if anyone has noticed this but tomei has a ECU, Headers, TPs, and more for sale w/ USDM prices on their website:
http://www.tomei-p.co.jp/vq35/vq35_en.htm
Anyone think that their ECU might be worth the purchase? Its cheaper then UTEC and from what i can see, gives = gains. Also, their headers are decently priced, and hell, their entire header/TP/ECU package for 2000$ is cheaper then what it would cost to buy other brands over here stateside.
Old Mar 29, 2007 | 04:20 PM
nismology1's Avatar
nismology1
Most people don't go aggressive enough with the cams. Until i see someone with nismo spec 2 cams or equivalent, 12:1 compression or higher, headwork, larger MAF housing or eliminating it completely, and long-tube headers there's power being left on the table.
Old Mar 29, 2007 | 04:53 PM
scratch137's Avatar
scratch137
by long tube header, you mean headers that go all the way to teh y-pipe. Basically eliminating cats,TPs?
Old Mar 30, 2007 | 11:34 AM
scratch137's Avatar
scratch137
Can anyone answer any of these?
Old Mar 30, 2007 | 12:25 PM
LG_z33's Avatar
LG_z33
The Amuse car runs high compression pistons in conjunction with the other parts listed by the op. I would also like to know what gas they achieve their numbers with and what dyno they use.
Old Mar 30, 2007 | 12:28 PM
Mantis77's Avatar
Mantis77
They most likely run extremely high compression along with 100+ octane fuel.
Old Mar 30, 2007 | 12:40 PM
Motormouth's Avatar
Motormouth
I would like to see some dynos.
and I never see WHP quoted from japanese tuners, it's always BHP or crank hp.
and the last time I heard about their cars, they were hitting just under or over 300hp (whp?) with fully built lower ends but stock airbox in this > http://www.jdm-option.com/eng/featur...2/z33_v35.html < shootout.
I call BS.
Old Mar 30, 2007 | 01:42 PM
Nismo 350z's Avatar
Nismo 350z
I call BS.
I wouldnt call BS. The Nismo RS Concept hit 340whp on a dynapack. Read it on the link you provided. Also the new Nismo 380RS is making 395bhp. Do the math and calculate rwhp yourself. So a fully built NA motor with ITBs, long tube headers, MAF and DCW disabled, agressive cams, race gas, and hc pistons should gain more than that. Adding a stroker kit should provide with more power. Thats what the 380RS did. 3.8l stroker kit, long tubes, but dont know much about internals.
Old Mar 30, 2007 | 06:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. going for 400 whp and coming close to achieving it are 2 completely different things
2. every car you see that is remotely close (highest right now is in the 350-360 range on a Dynapack) are running compression from 13 to 13.5:1
3. they have virtually unlimited budgets
NA costs $, period, to do so in a reliable fashion.
Old Mar 31, 2007 | 08:56 AM
Nismo 350z's Avatar
Nismo 350z
Originally Posted by Z1 Performance
1. going for 4000 whp and coming close to achieving it are 2 completely different things
NA costs power, period, to do so in a reliable fashion.
Exactly but we all know NA is more fun to drive than FI.
