Kinetix V+ rubbing hood...
Old Apr 21, 2007 | 01:53 PM
halfass872's Avatar
halfass872
Default Kinetix V+ rubbing hood...
Poped the hood today after having my V+ plenum installed for a few days, and i noticed a small bare metal spot on one of the "braces" under the hood. And a corresponding orange smudge towards the driver's side of the plenum. It seems to only rub when the engine torques, cause i can't feel any vibration when i feel the hood at idle. But when i rev it at idle, i can see the hood move slightly. I'm not too concerned cause it hasn't left any marks on the outside of the hood. But now that i know it's there, i was wondering if theres an easy fix to this, or just deal with it? Thanks!
Old Apr 21, 2007 | 04:20 PM
SpoilsofWar's Avatar
SpoilsofWar
My V+ has done the same thing (on both the stock hood and my Vis CF hood) for about 20,000 miles now. Eventually, it stopped after rubbing maybe 1/32 of an inch off the plenum. It will "self clearance" if you know what I mean, lol.
You may want to install an engine torque damper. But otherwise, dont sweat it.
Old Apr 21, 2007 | 04:28 PM
halfass872's Avatar
halfass872
Thanks man!! I was thinking the same, as far as "self clearance" goes. I guess that's another good thing about having a plastic plenum. I guess we definatly know they utilized every millimeter of underhood space for the plenum!!
Old Apr 21, 2007 | 06:08 PM
MustGoFastR's Avatar
MustGoFastR
Yeah, I kinda figured it would self-clearance after a while, as the plastic appeared to have work down a bit. No worries. Funny thing is, it's the raised design in the top of the plenum that's rubbing, not the top dome of the plenum itself. You'd think they could have shaved a bit off there, so that wouldn't be an issue...
I have a TQ dampener, BTW. Also have the Stillen master cylinder brace. FYI, the strut bar spacers make the bolt that secures the master cylinder brace too short (the nut is fine), so a longer one is needed.
Old Apr 22, 2007 | 03:15 AM
halfass872's Avatar
halfass872
Great info thanks!
Chiefryback
Aug 6, 2008 10:30 AM
gimpster621
Southern California
Mar 6, 2008 09:01 PM
theZman
Mar 16, 2007 04:51 AM
Changvi
Northern California
Sep 9, 2006 07:07 PM
Changvi
Sep 9, 2006 12:13 AM
