Oil catch can install
Old Apr 28, 2007 | 03:54 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Default Oil catch can install
This is my first attempt at installing my greddy catch can. The only problem I have is that the tubing that came with the kit becomes compressed when the vacuum is being pulled.Wonder if anyone else that may have tried to use the clear tubing had this problem. I even tried putting "stints" into the tubing so that it would not compress.Any suggestions on this or comments would be cool. I am thinking about using something more along the line of fuel line instead of the tubing that came with the kit.And I need to tie it up when I get the tubing like I want it. It fits super.Sorry for the big pictures. Its a work in progress.Thanks
[/IMG]
[/IMG]
Old Apr 28, 2007 | 05:18 PM
derekinthez's Avatar
derekinthez
bump
Old Apr 28, 2007 | 05:23 PM
tcoraccio's Avatar
tcoraccio
Use Fuel Injection hoses, they stiffer and won't compress, try to keep the length as short as possible.
you can find the hose at autozone
Old Apr 28, 2007 | 06:39 PM
VIZAGE's Avatar
VIZAGE
I saw some clear tubing on DJ Smitty car that had what seem to be a metal coil of some type in the tube to keep it from collapsing. You could PM him to find out.
Old Apr 28, 2007 | 07:44 PM
MotoWillis's Avatar
MotoWillis
I got it figured out. You don't need clear hose anyway since the can has a sight tube. I'll talk to you tomorrow
Old Apr 28, 2007 | 08:58 PM
ZCARBANDIT's Avatar
ZCARBANDIT
my thought as well. black would look better any way.
Old Apr 28, 2007 | 09:21 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
There are other options as well. Vacuum tubing (for mechanical vacuum pumps) sometimes has a metal coil built into the tube to resist crushing. Also, you could look into some thick tygon tubing from Fisher scientific.
Just thought I'd throw that out there.
Old Apr 28, 2007 | 09:24 PM
ZCARBANDIT's Avatar
ZCARBANDIT
thanks for that info. Ill have to look up tygon tubing and see.
Old Apr 28, 2007 | 09:32 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I just found this website, towards the bottom right, they talk about thick-walled vacuum tygon tubing
http://www.stiflow.com/p_tygon_R3603.htm
I'm not sure, but it might be too pricey for this kind of application.
I only mentioned it because since I work in a lab at UCLA, I can get this stuff for free/cheap
Old Apr 28, 2007 | 09:55 PM
ZCARBANDIT's Avatar
ZCARBANDIT
thats some interesting reading there. they have all kinds of tubing. thanks
Old Apr 29, 2007 | 01:11 AM
Chad68's Avatar
Chad68
To keep with my rice theme LOL, I used braided line on mine, instead of the garden hose that was too short anyway.
Old Apr 29, 2007 | 06:12 AM
MustGoFastR's Avatar
MustGoFastR
Just go with fuel line tubing. That's what I use; it's cheap and works great.
Old May 1, 2007 | 07:01 PM
rct350z's Avatar
rct350z
use some black rubber hoses like the water line from your intake manifold that **** is strong as hell
Old May 1, 2007 | 07:07 PM
ZCARBANDIT's Avatar
ZCARBANDIT
I ended up using fuel line from west marine. it is strong and seems to hold up well to the heat. I just need to use some DG clamps that I used when I worked on planes and make a T from the harness to the fuel lines to make it look more professional and to help lower the hoses a little and to support them.Thanks for the input and any more that may be put on here.
Old May 2, 2007 | 10:50 AM
gothchick's Avatar
gothchick
+1. I used fuel injection line on mine. Any automotive parts store will have it. Works great.
apex locator
Jul 23, 2021 02:27 AM
