Oil Pumps - revup vs nonrevup
Old Apr 29, 2007 | 03:26 PM
Nietzsche's Avatar
Nietzsche
Default Oil Pumps - revup vs nonrevup
I searched and couldn't find the answer. The FSM doesn't state a difference in oil pumps between the two motors so what is it. The have the same specs for oil pressure. Is it really necessary for revving to 72-7500 rpm?
Thanks
Old Apr 29, 2007 | 05:06 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The rev up pump doesnt necessarily flow anymore volume of oil, but it was designed for higher RPM operation. It's cheap insurance when building an engine.
Old Apr 29, 2007 | 05:07 PM
Gumpdriver's Avatar
Gumpdriver
+1 what Sharif said.
Old Apr 29, 2007 | 06:53 PM
Nietzsche's Avatar
Nietzsche
Do you run any risk by revving into the 7's without it? It's alot of labor time if your not doing anything else to the engine.
Old Apr 29, 2007 | 09:07 PM
Sharif@Forged
Forged Performance
I wouldnt change out the pump, unless you are planning to build your engine.
Unfortunately, your question cannot be answered 100%...we would just be guessing.
Old Apr 30, 2007 | 03:02 AM
Nietzsche's Avatar
Nietzsche
I'll have to see if I can find some one in corporate to tell me the differences.
Old May 1, 2007 | 08:20 AM
nismology1's Avatar
nismology1
Like i said over on maxima.org, the standard oil pump is good for at least 7500 RPM.
Old May 1, 2007 | 04:30 PM
Nietzsche's Avatar
Nietzsche
Well excuse me for asking 350z owners I just want to be double sure. When I swap internals I'll swap it out, but until then I don't want to kill her.
Old May 1, 2007 | 04:43 PM
Eazzy's Avatar
Eazzy
I would venture to say no. OPs have changed little, in all engines in the last 40 years. Up Grades are generally Higher Volumn or Higher Pressure. I would say that they may have gone with a Higher Volumn Pump, Higher Pressure would be of little use and never has been the way to go.
If they are interchangable, do it if you build the motor, but I just cant see doing it as a single mod
Disclaimer: IMO
Old May 1, 2007 | 04:45 PM
Eazzy's Avatar
Eazzy
I might add---- and am ready for a rant, But the bottom line is, an engine is an engine and the same basic rules apply in most cases
Old May 6, 2007 | 05:29 PM
rrmedicx's Avatar
rrmedicx
Is there any where else to get one than from the Stealership?
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
