HKS ignition
Old May 4, 2007 | 05:18 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by sentry65
the way I understood it, you might gain some slight power because the flame is bigger and more intense so you absolutely burn all the air/gas mix while it's in piston chamber instead of 90-95% or whatever of it, then the rest burning as it's exiting through the headers and finally burned for sure by the cats - if cats are installed
so I'd think for cars with test pipes and FI, the HKS will reduce the chances of shooting flames out the back of the exhaust since it'll burn more in the cylinder chamber
a bigger and more efficient explosion in the cylinder chamber means more power is being made to turn the crankshaft
I don't see how bigger spark = more combustion. The spark just starts the combustion, after it begins, it's a chain reaction which keeps going automatically.
The amount of uncombusted material in your combustion chamber will depend on things like the efficiency of the combustion chamber, air/fuel ratio, and so on.
If a bigger spark causes more efficient combustion to occur then I'd be very surprised.
Old May 4, 2007 | 05:31 PM
sentry65's Avatar
sentry65
the burninator
well, I don't know what to say. Don't buy it.
Alberto, me, and other members have noticed a difference in smoother idle, stronger start up, and the car somehow feels more OEM in how smooth it runs with the HKS. I'd buy it again.
there's less chance of spark blowout and it's a stronger spark. Air, gas and spark = power. So if you add more air and more gas, why not more spark?
otherwise you'd have to wonder why the extreme hp cars run crazy strong ignitions and not the same ignition off of a geo metro and save some cost and weight
Old May 4, 2007 | 07:52 PM
Reyes5937's Avatar
Reyes5937
Thanks for your answer Sentry65. So if I get the HKS will I still be able to run with my Ultimate Grounding kit or would I have to part with it?
Old May 4, 2007 | 07:54 PM
sentry65's Avatar
sentry65
the burninator
the grounding kit is a completely different thing
the HKS plugs directly into the ignition coils
the grounding kit is just a bunch of copper wires you attach from the chasis to the engine
I wouldn't say the HKS is a big deal item, but it is noticeable. They say you get better gas mileage since the gas burns more efficiently inside the engine, but I don't think it was a big deal on my car. I mean, it probably made some difference - like a 1% difference in MPG or whatever. Nothing I've actually noticed though. The engine does seem to run in a more confident way though.
Even nissan's new HR engine supposivly has bigger coil packs because it revs higher. That might be a possible other option if those coil packs fit in the older VQ's.
Old May 5, 2007 | 06:22 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I'm with Wired on this one...
I cannot comprehend how these can make a difference for anything but FI at high loads/flow rate. Or with methanol or nitromethane based systems or any other system that utilizes very high flow rates. Of course, I could be wrong on this but the way I see it is ignition is either achieved or it isn't.
Changing the intensity of the spark won't change the intensity or efficency of the combustion reaction that follows. You could increase spark energy by a factor of 10 or even 100, but the F/A mix will still deflagrate at the same velocity and efficency.
The only way I can see it possibly making a difference is if the spark was so close to the low side of the ignition threshold that it was almost at the point of not achieving ignition (resulting in occasional misfire) or if it was so weak that it created a slight variability in the onset of ignition (resulting in a slight variability of "effective" timing).
But for either of these hypothetical situations to happen it would require the stock system to be marginal in design. And I know the engineers at Nissan wouldn't do that. They can easily design in a 10X margin factor like a piece of cake. Spark systems aren't hard to overdesign at all once you know the method. It won't tangibly change the cost either.
Nissan would also be very careful to avoid misfires or variability in the ignition time because it would quickly affect emissions. And you know the engineers have to be paranoid of anything that could possibly increase emissions.
So I just don't think they would cut corners on something so simple and leave it right at the ignition margin.
Its not a plausible scenario.
Old May 5, 2007 | 12:02 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Definately two sides of this fence, and personally...we are kinda in the middle. On high boost cars, where the chances of spark blow out, or an otherwise less than ideal ignition event is more likely....ignition amplifers can work very well. But on an NA car, or moderate boosted engine, the factory ignition system should be sufficient.
The challenge with before and after dyno testing, when trying to discern a 3-5whp gain, is the margin of error between runs. We all know, that engines will produce slightly different power from run to run...on the same dyno. It's like trying to determine if an engine oil adds power....its almost too close to call.
It would make for interesting before and after dyno...however, to see if the curve is "smoother" than OEM.
Old May 5, 2007 | 12:04 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Not scientific by any means but--->my experience
I trapped 114mph with a high of 115 in 45 degree weather with the TN kit
In 95 degree heat with no changes to the tune and the DLI I did 115mph all day long and hit a few 116mph traps. It confirmed for me what I had felt which was better top end pull. Believe what you want....
Old May 5, 2007 | 12:46 PM
sentry65's Avatar
sentry65
the burninator
yeah I wouldn't bother with the HKS if I was NA or just wanted to burn some cash.
Old May 5, 2007 | 06:58 PM
rcdash's Avatar
rcdash
I've scoured the Internet for hours looking for some data to support its use (actually had it in my upcoming build sales order). In the end I could not find one fragment of data to support it's cost. So it's been nixed.
My theory is that for plugs that are slowly fouling (which will happen more quickly with colder heat range plugs), the ignition amp may prevent misfires. However, if the spark plugs are kept in good shape, I wouldn't think it would be much of an issue. I would be interested to know if you could tune more aggressively with 2 step colder plugs compensated for by using an ignition amp to help prevent misfires due to fouling (if it can actually do that).
Who knows???
Old May 6, 2007 | 06:41 PM
Lawn Dart's Avatar
Lawn Dart
I found some good information.
Link
Old May 6, 2007 | 07:48 PM
sentry65's Avatar
sentry65
the burninator
nice link
Old May 6, 2007 | 08:31 PM
IIQuickSilverII's Avatar
IIQuickSilverII
i guess this is nice to have but not a "must have" part.
I am sure the iddle might be batter and that might lead to the butt dyno telling you are faster =]
Old May 7, 2007 | 10:58 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I don't doubt your experience, but that is a little too close to call IMO. Your experience could go either way if you ask me.
You could've been shifting slightly better, had a more optimal psi in your tires, less heat soak in your engine bay, or something else to explain the improved performance.
Old May 7, 2007 | 02:10 PM
rcdash's Avatar
rcdash
None of us know what the stock ignition system specs are, so how can anyone make even an educated guess about what an aftermarket system will do to help?
Old May 7, 2007 | 02:41 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Link
i agree with sentry that is a good link to learn about the ignition systems in many cars.
Old May 7, 2007 | 03:32 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I always shift slow you know that. The weather was against me and I still trapped 1 and 2mph higher ALL day long. Pushing a car like I do, that is a noticable improvement. The track day only confirmed what I had felt immediately. Too bad I never got to retune with a larger plug gap
Old May 7, 2007 | 03:43 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I trust your opinion, and I'd love to try the HKS unit for myself, but for the price I cannot forsee doing that. Because even if you say so, the theory still doesn't work out for me in my mind, at least not enough for me to go out and buy the unit. But your endorsement seriously means a lot IMO with a product like this.
Old May 7, 2007 | 03:54 PM
  #38
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks. I would not recommend this to anybody but FI guys. If I remember to do so, maybe next time I have the chance I'll take a few minutes and disconnect the unit and see if it dyno's lower.
Old May 7, 2007 | 03:56 PM
  #39
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
That makes sense too. Again, thanks for your input and if you could see the difference on the dyno, that would be great as well.
Old May 7, 2007 | 04:33 PM
  #40
stormcrow's Avatar
stormcrow
i don't think it's about more combustion, but quicker burn... detonation is caused by uneven mixture burn and can cause the familiar busted ringlands and pitted/melted pistons... greater spark causes more of the mixture to be ignited and therefore a quicker, more even combustion... granted, ignition and combustion are a chain reaction, but the shorter the amount of time between ignition and full combustion, the better...
that said, i had mine installed today for a different reason... i'm continually getting the P0300 (random cylinder misfire) and i figured i'd try 2 step colder plugs and the HKS DLI II... SES light has yet to come back on...but, only time will tell... i'll keep you guys updated...
