Took me 6 hours to replace a tranmission
Old May 21, 2007 | 12:07 PM
gcoupeturbo's Avatar
gcoupeturbo
Default Took me 6 hours to replace a tranmission
... after 6 straight hours of changing my (damaged) CD005 transmission to a CD009 transmission, i pressed the clutch pedal down... AND IT GOT STUCK ON THE FLOOR!
1. I installed everything correctly using the old pitchfork and throw-out bearing from the CD005 transmission..
2. Came to find out that this round ended 17mm BOLT from inside the bellhousing WAS MUCH SHORTER.. (CD009 transmission must have a new type of pitchfork)
3. So i spent the next 6 hours the next day taking it out and installing the LONGER Round-ended 17mm BOLT inside the bell housing.
Now everything works just fine.. and shifts soooo smoothly
What a waste of a day... if u ever get a newer transmission put it.. make sure to compare all components of both transmissions!
Old May 21, 2007 | 03:57 PM
ke0ki2k's Avatar
ke0ki2k
hey, are there different transmissions for each model year? or is the 009 like special order? i dont know jack about the trannys
Old May 21, 2007 | 03:59 PM
symalik's Avatar
symalik
the 009's are the latest revision of the transmission, i think started with 05's and so on
Old May 21, 2007 | 04:21 PM
westpak's Avatar
westpak
SFZCC
why did you have to switch parts over, when I changed mine it came with everything.
Old May 21, 2007 | 04:27 PM
gcoupeturbo
i bought it from someone and it needed the pitchfork, throwout bearing and the revese switch sensor..
my previous tranmission was crap... im so glad i switched over to the new one..
Old May 21, 2007 | 07:47 PM
DIGItonium's Avatar
DIGItonium
If you read Sharif's thread, the CD -009 (2007 Z Transmission?) does away with the fork. It is different.
Old May 21, 2007 | 07:51 PM
Eazzy's Avatar
Eazzy
Never reuse your throwout brg. Christ, you were RIGHT there !!!!
Old May 21, 2007 | 08:06 PM
gcoupeturbo
throw out bearing was new.. i just had it installed in the new tranny about 1 week ago @ altered.. this was when i had a motor swapped out with the PE TT, also got a new flywheel
Old May 21, 2007 | 08:07 PM
gcoupeturbo
can't find his thread.. to many of them... can you send me a link?
Old May 21, 2007 | 08:08 PM
Eazzy's Avatar
Eazzy
Then you'r forgiven
Old May 21, 2007 | 08:51 PM
DIGItonium's Avatar
DIGItonium
https://my350z.com/forum/showpost.ph...&postcount=195
It made me wonder as well. Clutch engagement is terrible. I'm not quite sure if it needs adjustment. It seems like I have to press the clutch in fast before releasing for it to engage smoothly. If it's too slow, it feels like the engagement is too high so I tend to gas earlier causing it to jerk. This didn't happen when I first got my car in 2002 and I was just learning. The one I have is about 1.5 years old. It was nice and smooth the first few months, and then it's back to clunkiness.
Old May 22, 2007 | 11:29 AM
gcoupeturbo
wow, didn't realize they just decided to do away with the clutch fork and the external slave cylinder..
at least parts from the old transmission can still fit in there..
Do the 07's have a different design than the 06's?
The transmission i got is a CD009 from an '06 Z
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
