Question about Auto Tranny Coolers.
Old May 23, 2007 | 05:12 PM
THE TECH's Avatar
THE TECH
Originally Posted by danielwebb
actually if you would read the question its not about a VB upgrade at all its about a tranny cooler. So this would not be an example of me asking a question and not liking the answer to it, because most of you aren't answering the question. And you guys must have missed a crucial piece of info FORGED DOESN'T OFFER THE VB UPGRADE ANYMORE they were having some "issues" with it. So I guess you geniuses don't know as much as you think after all.
G'day
Actually, if you reread your own post, you equated this new VB to be causing high heat which you need the tranny cooler for. So if you got a quality VB upgrade, you might not need the tranny cooler.
Old May 24, 2007 | 02:44 AM
DanielW's Avatar
DanielW
Doesn't the VB produce more heat the harder it shifts?
Old May 24, 2007 | 04:54 AM
coachk's Avatar
coachk
I recommend a tranny cooler if you run the car hard,period.....Web Site is BMRACING.com....I have the HiTek auto tranny cooler w/ electric fan&thermal switch.Fan flows 350cfm....part# 70298
Old May 24, 2007 | 05:40 AM
THE TECH's Avatar
THE TECH
Most of the heat produced by the transmission comes from the torque converter.
Old May 24, 2007 | 06:22 AM
coachk's Avatar
coachk
Agreed ^^^^
Old May 24, 2007 | 06:31 AM
roncfpz's Avatar
roncfpz
Excellent choice. I went with the 500cfm fan and it works great. I would say based upon the OP desired power level the 350cfm would be fine. Any kind of hard driving really stresses the auto trans and temps rise fairly quick.
If you cannot get the valve body upgrade from FP any longer I would then highly recommend SGP. The underlying consistent message from those with experience is do NOT get the Level 10.
Old May 24, 2007 | 06:37 AM
Ghost 350z's Avatar
Ghost 350z
dude
Seriously...............
DONT USE LEVEL 10 CRAP. YOU ARE WASTING YOUR MONEY!!!!!!!!!!!!!!!!! SGP
Maybe you will see it now ?
Old May 24, 2007 | 07:19 AM
THE TECH's Avatar
THE TECH
Originally Posted by Ghost 350z
dude
Nah, probably still not big enough.
Old May 24, 2007 | 07:50 AM
DanielW's Avatar
DanielW
I'm going with level 10 will you guys please just let it rest. It is the only practical choice i have sgp doesn't offer a deal where you can pay a refundable deposit to have them ship it to you before they get yours. I have to get my car back. Its my daily driver. Now please just drop it. Thanks for the info on the tranny cooler I'll check out the 350cfm
Old May 24, 2007 | 05:47 PM
helldorado's Avatar
helldorado
I don't see how you can do a VB swap since you have a 2005. Your TCM is integrated into the VB. You need your VB modified. If you swap, you run the risk of them sending back a pre 2004.5 VB which won't have a TCM, or how do you expect your car to run when if you get a TCM isn't synched to your ECU?
Torque converters generate much more heat than valve bodies.
Old May 24, 2007 | 06:12 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
What good is cheap & quick turnaround time if you buy a crap part that increases the likelihood (versus your stock tranny) of a transmission failure that will lead to even greater downtime (and inconvenience) with your daily driver??? Do it right the first time!!!
Seriously... THESE GUYS ARE TRYING TO HELP YOU!!! Like the moderator Wired 24/7 already alluded to... you seem to be too stubborn to realize it.
Good luck with your choice.
Old May 24, 2007 | 06:13 PM
Accordaleer's Avatar
Accordaleer
Default Great site
http://auto.howstuffworks.com/torque-converter.htm
Old May 24, 2007 | 06:20 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
a crap part is not practical no matter how you look @ it.
Old May 25, 2007 | 04:56 AM
DanielW's Avatar
DanielW
ok I am hearing what you guys are saying. That being said the part has been purchased. I have to go with what I have right now. I will write up a full report on this VB after a few weeks of use and acknowledge all of you guys for telling me it was crap if the part doesn't work for me. I'm not even arguing that the part is good, and maybe if I would have had this input before I paid for it I would have done something different but for now can you guys please just accept that I'm stuck with what I got?
Old May 29, 2007 | 02:03 PM
rcdash's Avatar
rcdash
I believe this is the one I got (14,400 btu):
http://store.summitracing.com/partde...5&autoview=sku
And will hopefully be installed right in front of the radiator so a separate fan will not be necessary.
Old May 29, 2007 | 03:50 PM
iStan's Avatar
iStan
ZR
Will a fan be necessary if it is receiving a good flow of air? I am planning on where the wiper reservoir was, and taking out the reflector to allow a nice flow of air directly onto the tranny cooler.
Old May 29, 2007 | 05:36 PM
rcdash's Avatar
rcdash
Well, if you've got enough airflow, then no, you would not need the fan.
Question is, how much is enough.
I want the radiator fan to cool my tranny cooler - we'll see if that's possible. That way, if I want more cooling, I can just get the radiator fan to turn on earlier.
Oh, and I will have a tranny (magnetic) filter in place also (magnefine brand).
Old May 29, 2007 | 05:38 PM
  #38
Fluid1's Avatar
Fluid1
I was gonna go with forged but its not on there site under auto transmission stuff anymore.
There's this thing called the telephone......
Cancel the L10 order. If you can't, sell it immediately and thank yourself for doing so.
Old May 30, 2007 | 04:19 AM
  #39
DanielW's Avatar
DanielW
Update: Road in the car last night at 5 psi. Car feels strong and VB shifts fine. Will update again when tuned and running at 7-8 psi
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
