central 20 3.9FD top end
Old May 28, 2007 | 01:20 AM
NISMO_558's Avatar
NISMO_558
Default central 20 3.9FD top end
I'm going to be installing the central 20 3.9FD gears in a few weeks, and i realize they help with 0-60 and 1/4 times, but they also make the car lose some of it's top speed. My ? is, how well do they work on top end acceleration?, lets say i'm cruising at 60mph and I down shift to 4th or 5th and punch it, will they make it accelerate quicker than stock just as it helps out 0-60?
Old May 28, 2007 | 07:08 AM
Armitage's Avatar
Armitage
Adding the 3.917 final drive boosts your acceleration approximately 10% in each gear from what I hear. The tradeoff is that you go from a max of like 156 mph top speed to like 150mph. It is such a good mod though because it only helps acceleration. It does not make you sacrifice top-end for low-end or vice versa.
If I'm not mistaken though, it also shortens each gear. I think 2nd stock tops out at 62mph but with the FD installed it may stop at like 58mph or something so to get to 60 you need to shift to third.
Anyone correct me if I'm wrong.
Old May 28, 2007 | 07:50 AM
ke0ki2k's Avatar
ke0ki2k
depends on the year. my 06' tops out at like 65 or 67 in 2nd gear, the new 07's probably hit like 72 if they havent tweaked the gearing. might be true for the 6600 redline cars though.
Old May 28, 2007 | 01:06 PM
ke0ki2k's Avatar
ke0ki2k
whered you order your 3.917 anyhow?
Old May 28, 2007 | 01:31 PM
sentry65's Avatar
sentry65
the burninator
the 3.9 FD lowers the gearing's top speed from 185mph to 165mph. You won't really nottice a difference since the ECU cuts off speed at 160mph anyway
and yes it'll improve accelleration in 4th, 5th, and 6th gear. It's noticable
Old May 28, 2007 | 09:12 PM
NISMO_558's Avatar
NISMO_558
vivid racing
Old May 28, 2007 | 11:54 PM
bbs350z's Avatar
bbs350z
dont add this if u go f/i because first gear is completely useless then, also when cruising, wouldnt ur rpms be a bit higher?
Old May 29, 2007 | 05:24 AM
clipso 01's Avatar
clipso 01
10% harder pulls in all gears
Old Jun 5, 2007 | 07:57 PM
windlun's Avatar
windlun
What about the faul consumsions? any big different after the 3.9 installation?
Old Jun 5, 2007 | 10:20 PM
Black Ztallion's Avatar
Black Ztallion
I love my gears. I definetly noticed a difference. My MPG dropped from 23 to 21.
apex locator
Jul 23, 2021 02:27 AM
hulkout
Apr 28, 2017 09:00 PM
pr_350z
Oct 1, 2015 05:03 PM
Depravity
Oct 1, 2015 04:49 PM
