2007 Trannmission issue.
Old Jun 14, 2007 | 11:53 AM
Mamounas123's Avatar
Mamounas123
Default 2007 Trannmission issue.
i got 2 questions guys. I bought my 07 z last tues and so far i love it but i have 2 questions about the clutch.
1) When i first start up the car when its cold there a rattling sound. Is this normal or is there a problem?
2)Also theres a sound when the clutch is in neutral its not a rattling sound but just a unusual sound. But when i press the clutch down it goes away. Is this normal or is it a problem.
3) I have not gotten the typical problems from the 07 with the 6th gear grinds , or the clutch stickin to the floor but just wanna make sure the top 2 problems are normal.
Old Jun 14, 2007 | 11:54 AM
Mamounas123
ALso my car has 384 miles if that matter anyways.
Richy350Z's Avatar
Richy350Z
yep. mine made the same rattling noise when I bought it! I sometimes feel like holding the clutch down at all times.
Old Jun 14, 2007 | 11:56 AM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
is this something dealer gonna take care the problem?
i am gonna drop my car off next tues for this problem..
but mine is 06 tho..
Old Jun 14, 2007 | 11:57 AM
blackstealthz's Avatar
blackstealthz
You should def go by the dealer and check it out just to be safe.Hey what part of boston u from im on the northshore.
Old Jun 14, 2007 | 12:01 PM
Mamounas123
Im live in the middlesex county. Not to far away.
Old Jun 14, 2007 | 12:02 PM
Voboy's Avatar
Voboy
um guys it seems like #3... means he DOESN'T have the 6th gear grind, or stuck clutch problem... he's only worried about the first 2? and the first two are just clutch rattling issues and that's completely normal.
Old Jun 14, 2007 | 12:10 PM
Mamounas123
Yeah just to clarify I DONT have the 6th gear grinds and I DONT have the cluthc stickin to the floor problem.
Old Jun 14, 2007 | 12:26 PM
trodis's Avatar
trodis
I am from Middlesex with an 07 too!
Old Jun 14, 2007 | 12:52 PM
fairlady350z33's Avatar
fairlady350z33
i have the same sounds coming from the clutch, and when i press it down it goes away... dealer said its normal as do a few other members on here.
my shifter also vibrates like crazy too, don't know if thats normal.
Old Jun 14, 2007 | 12:54 PM
mcurry5's Avatar
mcurry5
Mine does the same thing. I am thinking its normal.
Old Jun 14, 2007 | 12:55 PM
Richy350Z's Avatar
Richy350Z
oh yea did I metion, IT IS NORMAL
Old Jun 14, 2007 | 01:00 PM
z-u-later's Avatar
z-u-later
You should have bought an AT . . . you wouldn't have any of these problems.
Old Jun 14, 2007 | 01:10 PM
Z-T's Avatar
Z-T
I think I have the same sounds coming from my clutch. I didn't think it was "normal" but since everyone seems to have it, so be it. It drives just fine, so whatever...I'll drive it till it breaks or gives me a sure sign something is wrong. That's when I'll be forced to waste my time at the dealer...not a minute sooner. Lol.
Old Jun 14, 2007 | 01:32 PM
Blacryan's Avatar
Blacryan
I have the exact same issue as,
"2)Also theres a sound when the clutch is in neutral its not a rattling sound but just a unusual sound. But when i press the clutch down it goes away. Is this normal or is it a problem."
I noticed it and worried for a few, I wasnt sure but figured it was normal. Has been doing it since I got it.
Old Jun 14, 2007 | 08:19 PM
sibble's Avatar
sibble
1: yes
2: yes
3: perfectly normal, lots of cars/bikes do it
a friend of mine has a z28 that does it, its much louder. he has a slp flywheel too, and the clutch is pretty new. he actually holds the clutch a lot because he hates the noise, but i wouldnt do that all the time. the owners man. actually says not to hold the clutch excessively.
Old Jun 14, 2007 | 09:55 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I would say #1 and #2 are perfectly normal.... and if you want to pre-empt the clutch sticking problem, try flushing the brake/clutch fluid with a higher temp fluid like motul rbf600
Old Jun 15, 2007 | 09:08 AM
blackblack99's Avatar
blackblack99
My 07 makes the same rattle noise, I took it to the dealer, they agreed to just replace the whole transmission. It is a problem, do not just deal with it. Nissan needs to take care of the problem. If you get any problems from the dealer, fight them for it. do not just deal with it. Search for the other thread on here that goes into this problem in more detail. I am glad they are replacing the trans, but they said that over a month ago after going back and forth with the dealer about what exactly the problem is.
Old Jun 15, 2007 | 09:12 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
Stronger manual transmissions do make a little bit of noise, it's perfectly normal.
Mine does it, every other Z I've heard does it, 6-spd Supras do it, etc...
I don't even notice it anymore.
