Dyno sheet
Old Jun 16, 2007 | 08:20 AM
WalkerT's Avatar
WalkerT
Professional
Default Dyno 05 Base
Just posting it up to see what you guys think, And do I need a utec?
The 12-16-06 dyno 3 runs
popcharger
5/16 spacer
nismo exhaust
The 5-26-07 dyno 3 runs
Aem intake
5/16 spacer
mild port and polish
strup headers
nismo exh.
And the overlay of the best from both days.
Installed by me
I had a popcharger but here in texas the thing would heat soak bad.
I also have TP but just have not had the time to install them and redyno.
Same dyno
Attached Thumbnails Dyno sheet-walkert12-16-06.jpg   Dyno sheet-walkert.jpg   Dyno sheet-compair.jpg
Old Jun 17, 2007 | 06:18 AM
WalkerT's Avatar
WalkerT
Professional
Well I guess no one knows. I just wondered if I should get a reflash or utec?
Old Jun 17, 2007 | 11:00 AM
cvt's Avatar
cvt
it seems like you're not running very lean. a tune might help smooth that afr down and smooth out the curve...but i don't think it will make very big numbers.
Old Jun 19, 2007 | 04:33 AM
WalkerT's Avatar
WalkerT
Professional
What do you think will happen after the Test pipes are installed?
Old Jun 19, 2007 | 05:11 AM
rcdash's Avatar
rcdash
it will lean you out more and you may gain in some areas where you are now rich, but you may loose in other areas without a tune
Old Jun 19, 2007 | 06:40 AM
RebelinRI's Avatar
RebelinRI
Lean out more, smell of un-burnt gas, gain another 2-3whp more. Thanks for showing that by adding headers only gained you minimal gains. I've always augured this point. For N/A............ not worth it!!! I would tune. If you'll be adding more, get the Utec hands down! You can always fine tune with the Utec to your cars needs, and every car is different. Re flash will do you good too but you can't fine tune it. Up to you and how much you want to spend.
Old Jun 19, 2007 | 06:50 AM
WalkerT's Avatar
WalkerT
Professional
The header only cost me 140 and took me 8 hrs to install. Soo for 20 hp more and 10 tq in my mid range It seems worth it to me. (see the last dyno)
What do I need to gain more top end?
Cams?
Or will I be able to gain more top end with a tune?
Old Jun 19, 2007 | 07:02 AM
RebelinRI's Avatar
RebelinRI
You've done all your bolt-on's, so I guess it's up to you where you go from here. What are your plans? Stay N/A or going FI? I would think you need to tune now, but how you would tune would factor to which way you would tune. I still think Utec would be best because of it's tun-ability (if that's a word, hey it went through spell check ). BTW I did not look at the third dyno sheet, my bad. but that's something for me to reconsider.
Old Jun 19, 2007 | 07:05 AM
RebelinRI's Avatar
RebelinRI
and your A/F is a little goofy (lean), so UTEC it!
Old Jun 19, 2007 | 08:19 AM
WalkerT's Avatar
WalkerT
Professional
Thanks, I want to stay away from FI because for me that is when I just go buy a different car.
I dont want to have to constantly adjust a utec or can you just set it and forget it. I just have a busy schedule. Would I be able to get a good AF with a reflash? or am I at the point were it is utec or nothing?
My future plans are to just get it running better in the top end. I dont want much just to push the power closer to redline.
Old Jun 19, 2007 | 09:29 AM
RebelinRI's Avatar
RebelinRI
Utec you can set and forget it. I think I confused you by saying you can tinker with it. You have to know what you're doing with the utec so I'd suggest getting it tuned by a pro. I'm sure someone in the "tunning " section could help you too, since you're staying N/A. A re-flash can also help you. You tell them what you are running and they'll re-flash to give you better performance. So really it's up to you and your wallet. You'll need to buy the Utec and get it tuned and also be able to adjust if changing things on your engine. You can just get it flashed and get gains but probably not the last bit of hp out of the engine that you could. Hope I didn't confuse you even more.
Old Jun 19, 2007 | 03:28 PM
GolfinZ's Avatar
GolfinZ
One word Travis...UpRev.
Old Jun 20, 2007 | 04:40 AM
WalkerT's Avatar
WalkerT
Professional
Spoken from uprev best sales man! I am leaning that way. PMed you Brain
Old Jun 20, 2007 | 02:32 PM
GolfinZ's Avatar
GolfinZ
I need some more go parts...Im tired of seeing your 1/4mile times lower than mine
Old Jun 21, 2007 | 04:24 AM
WalkerT's Avatar
WalkerT
Professional
I spoke with uprev they said that they could help get me 10-15hp at different point in my rpms. Temping but the price will be close to that of a utec. Hmmmm
Why have we not been back to the drags? it has not been that hot and I have test pipes waiting in my garage.
Old Jun 21, 2007 | 07:06 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Definately a lot of power is being left on the table. A UTEC and tuning would help you out.
Old Jun 21, 2007 | 08:20 AM
WalkerT's Avatar
WalkerT
Professional
Thanks
I am just weighing the opitions.
Old Jun 22, 2007 | 08:39 AM
GolfinZ's Avatar
GolfinZ
We will go on July 6th...thats the next fast friday event
Old Jun 22, 2007 | 10:18 AM
WalkerT's Avatar
WalkerT
Professional
I am there July 6TH
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
