ATTN: 2003 owners still on 1st transmission..
Old Oct 18, 2009 | 10:20 AM
  #181
j.arnaldo's Avatar
j.arnaldo
23,733k; NO issues. But, then again, mine's an AT, which are much more trouble-free than MTs in Zeds. Still, I'm glad to hear about all those flawless MTs on this post!
Old Oct 19, 2009 | 07:15 AM
  #182
danlee1's Avatar
danlee1
Those with transmission issues, do you rest your hand on the shift **** when driving? Also, do you rev match when down shifting? Just curious.
Old Oct 20, 2009 | 04:52 AM
  #183
bb1314's Avatar
bb1314
da Terminator!
I drive like a maniac at all time and I'm at 45,000 miles. Luckily tranny is still running strong!
Old Oct 20, 2009 | 10:45 AM
  #184
Jimmies's Avatar
Jimmies
How much are you guys paying to get the grinding fixed?
Old Oct 20, 2009 | 10:47 AM
  #185
Z Infidel's Avatar
Z Infidel
83K on 6spd. 3rd gear only grinds if I shift to fast/hard.
Old Oct 20, 2009 | 04:03 PM
  #186
AnthonyZ33's Avatar
AnthonyZ33
NEW tranny from Nissan 2700, to over haul they want 2000. this is in Ft. Lauderdale though so may be cheaper other places - getting mine this week this will be the second replacement
Old Oct 20, 2009 | 04:07 PM
  #187
AnthonyZ33's Avatar
AnthonyZ33
I always shift clean, NO clutch burning, NO jerking and still issues
Old Oct 21, 2009 | 07:01 AM
  #188
winterdevilg35's Avatar
winterdevilg35
well when i had my first transmission it had bout 83,000 miles on it with no problems then i snapped the pivotball by downshifting to hard. I replaced/upgraded that and a bunch of other transmission sh** like clutch, flywheel, pressure plate, clutch slave and master cylinder, clutch line, throwout bearing, pilot bearing, and a revo tecnica short throw shifter. I adjusted the gate (shifter to transmission plate) wrong and i was off by fractions of an inch and it caused my 3rd and 4th gear to grind out and my 5th to grind. I replaced the transmission with the best one a Z/G owner can get from nissan.(which is the CD0009 for those who dont know) i used my clutch arm and steel pivotball(long pivotball and lighter clutch arm) from my old transmission and put it on my new one. Or you can use the heavier clutch arm from the new transmissions and buy a steel pivotball(short pivotball) and use that. I used amsoil transmission fluid and my car is performing better than it was before my first transmission started acting up. So about 83,000miles on the CD0 #1 transmission driving it hard.
Old Jul 13, 2012 | 06:37 AM
  #189
engleman's Avatar
engleman
102,000 miles, first trans, first clutch, abused every-day.
Old Jul 13, 2012 | 07:41 AM
  #190
PerfZ's Avatar
PerfZ
122,000 on original tranny and clutch, '03. No issues whatsoever. Always rev match on downshifts. Track the car about every year, usually more than once, and 8 years of ZdayZ/Dragon and a lot of twisties every summer with my local club. Obviously a daily driver
Old Aug 22, 2012 | 03:13 PM
  #191
Delta_two-Niner's Avatar
Delta_two-Niner
'03 Touring 6spd manual on original clutch and transmission. No prob's except that damn squeeky clutch...searching forums now for a damn fix.
Old Aug 22, 2012 | 04:04 PM
  #192
Z_on_TE37's's Avatar
Z_on_TE37's
03 Track Edish. 49,xxx and im still good. No problems at all....knock on wood.
Old Aug 22, 2012 | 10:49 PM
  #193
hazehkg's Avatar
hazehkg
03' 6mt, 5th gear started to grind when shifting quickly a month ago...
I was wondering if replacing an LSD will also incur the removal of the transmission assembly. If so, I may consider to replace my LSD at the same time.
Old Aug 23, 2012 | 12:01 PM
  #194
harman850t5's Avatar
harman850t5
Your diff will be untouched, other than removing the driveshaft from it.
03 base, 59,978 on first trans so far.
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
