castrol syntec or penzoil
Old Aug 6, 2007 | 11:11 AM
SuperBlack350z's Avatar
SuperBlack350z
Originally Posted by izmir41500
Wal-mart also sells a 5 qt jug of Mobil1 for $19.95
actually those are 4 qt jugs so you have to buy an extra quart for 5 bucks so 25 in total.
Old Aug 6, 2007 | 12:32 PM
redlude97's Avatar
redlude97
which is also not a "true synthetic" oil
Old Aug 6, 2007 | 12:42 PM
Biochem7's Avatar
Biochem7
Regular
Why do people judge oil based on this fact. My oil analysis with regular dino Castrol GTX was perfect and performed as well as synthetics that were 2 to 3 times the price.
Old Aug 6, 2007 | 12:55 PM
redlude97's Avatar
redlude97
I'm not, just pointing out that the mobil1 isn't any "better" than the castrol syntec that can be had at walmart for ~same price
Old Aug 6, 2007 | 01:27 PM
Resolute's Avatar
Resolute
To answer the OP's question.. I'd have to go with Pennzoil Platinum over the Castrol Syntec. That being said, I don't have any UOA's done on the Syntec and there are a few weights I've been curious about. But, the PP 10W-30 is a great performing oil for regular oil changes.
I don't get the Royal Purpl hype at all. There is nothing that shows their oil to be any better, or even as good as, the other synthetics. Same for Motul, though. Both the UOA's done on the 300V and 8100 5W-30 aren't very good. Especially for the price.
Don't be swayed by the whole, "it's not a synthetic" or, "only Esters are the best base stock" arguments. If it was as simple as having the best base stock and a set amount of additives to make the best oil, then everyone would have basically the same formula. Some oils' formulation work better in the VQ35 than others. The top picks -based simply on the test results because I don't give a care for brand favorites- is:
Pennzoil Platinum 10W-30
Castrol GTX 5W-30
Mobil 1 0W-40
and if you like to order your oil, then:
Amsoil TSO (series 2000) 0W-30
Schaeffer's 5W-30
Any of the above will be GREAT in your engine. And because people seem to be asking me this a lot lately, I'll add that I am currently using Rotella T-Syn 5W-40 right now to get a UOA done on it. After that, it will be something else to get a UOA done on, maybe Castrol since there aren't any done besides the German Castrol 0W-30.
Will
Old Aug 6, 2007 | 02:27 PM
Biochem7's Avatar
Biochem7
Regular
Castrol GTX 5W-30
Mobil 1 0W-40
Schaeffer's 5W-30
Will
I should have a Syntec 5w-30 with ~5,000 miles (K&N oil filter) oil analysis report for you soon.
Old Aug 6, 2007 | 02:35 PM
Resolute's Avatar
Resolute
Sweet! Thanks, looking forward to seeing it.
Will
Old Aug 6, 2007 | 02:36 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
pick whatever you like... i don't see a need to start another what oil is best thread, so if you want such opinions please search
derek173
Jul 11, 2011 07:46 PM
Mike Wazowski
Southern California
Nov 15, 2007 07:35 AM
shushikiary
Nov 4, 2006 07:35 AM
mwaller
Jul 15, 2004 09:46 AM
Superfly84zx
Mar 31, 2004 06:37 AM
