RPM based ticking noise?!????
Old Aug 14, 2007 | 05:08 AM
mzdfc3s's Avatar
mzdfc3s
Default RPM based ticking noise?!????
ive spent all morning looking thru old posts but really cant find any info that is revealing.....on the way to work this morning after about 35 minutes or so, when approaching a light i bumped the revs to match 2nd gear and started decelerating. from about 4k down to 2.5k i got a really unusuall ticking coming from what sounded like was right behind the dash or underneath the dash right in front of me. so i pulled away and got the same thing w/accel starting at 2.5k all the way up. when it comes it is slow, and become very fast when the RPMs get higher.
i really wouldnt expect injectors or valves to sound like this. car only has 2300 miles??? any thoughts.
Old Aug 14, 2007 | 05:53 AM
maximumsportZ's Avatar
maximumsportZ
You have oil in your car right?
Old Aug 14, 2007 | 05:58 AM
mzdfc3s's Avatar
mzdfc3s
Old Aug 14, 2007 | 06:11 AM
jtabraham's Avatar
jtabraham
Does it sound like current arching? I had a similar problem in a previous car where I had some arching in one of my coil packs that would tick proportionate to the speed of the engine.
Old Aug 14, 2007 | 06:51 AM
mzdfc3s's Avatar
mzdfc3s
uh, well im not sure....where are the coil packs located? it did seem to be louder as i got closer to redline. it wont do it when the car is not moving aka-just revving it. a free rev while moving it would do the same thing at the same rpms though?
Old Aug 14, 2007 | 07:03 AM
maximumsportZ
The injectors on our car's are known to be noisy and produce a ticking noise. Is it a tick or a tap like metal to metal ?
Old Aug 14, 2007 | 07:25 AM
jtabraham's Avatar
jtabraham
Because our cars are direct-injected, there is a coil pack over each cylinder.
Let the car idle and see if you can determine where the ticking is coming from. You may want to buy a mechanics stethoscope from harbor freight ($5.99)
Old Aug 14, 2007 | 07:29 AM
mzdfc3s's Avatar
mzdfc3s
theres no tick at idle, it doesnt sound like metal ticking...maybe more towards a plastic sound, i dunno?
Old Aug 14, 2007 | 08:03 AM
failsafe306's Avatar
failsafe306
Try unplugging the sensor harness from your EVAP control solenoid, that's bolted to the plenum, near the back passenger side. You'll get a CEL, but if the noise stops, it's a bad solenoid.
Old Aug 15, 2007 | 03:13 AM
mzdfc3s's Avatar
mzdfc3s
well, it didnt do it on the way home yesterday...but sure enough it was ticking away on the drive into work today!?! the last two days it was <60 degrees for the morning commute, so that must have something to do with it?
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
