Stormcrow fixed the knocking sound in my Z
Old Aug 21, 2007 | 01:32 PM
Beeker's Avatar
Beeker
The link I posted explains it perfectly with pictures. Page 3 has a pic with circles around where the hoses go. The catch can goes in between the PCV valve and the intake plenum. If you remove the engine cover you will see a hose that comes from the valve cover on the passenger side (pcv valve) and goes to the intake plenum in the front.
When you install this connect a hose from the pcv valve into the catch can. Then the output part of the can connects to the plenum. There is an arrow on the can that shows the proper direction. Thats all there is to it.
Old Aug 21, 2007 | 09:05 PM
fairladyz47597's Avatar
fairladyz47597
Originally Posted by bugsbbunny
Hmmm might have to try this out... I'm getting horrible knocking...
Do you mind taking more detailed pics of how it was installed? Like where the 2 hoses go? I read the other DIY but it was kind of vague.
yeah...it's real easy to do. i'll take some more pics this week if you still need them. i wasn't able to today because i worked til 1 am... i will do it once work slows down, though.
Old Aug 21, 2007 | 09:18 PM
Mazinger Z's Avatar
Mazinger Z
Just curious, how much did it cost for everything?
Old Aug 21, 2007 | 09:20 PM
fairladyz47597
30 dollars.
cheap fix.
Old Aug 22, 2007 | 06:33 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Great to hear!
Old Aug 22, 2007 | 10:34 AM
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by Sharif@Forged
Great to hear!
This seems like a miracle cure for knock.
I'm curious if you put a catch can on the cars you build? Do you think a catch can is a good idea for NA cars, too?
Old Aug 22, 2007 | 10:52 AM
Mazinger Z's Avatar
Mazinger Z
Seemed to work for the OP. I'm going to try it out (already ordered a catch can). Can anyone verify how this would eliminate knock?
Old Aug 22, 2007 | 11:16 AM
Sharif@Forged
Forged Performance
Yes we do. Without control over timing, its probaly even more important for an NA car, since you are relying on the stock for timing control, and stock knock detection.
Old Aug 24, 2007 | 01:26 PM
Mazinger Z's Avatar
Mazinger Z
So a catch can is more than looks. It actually is a fix for engine knock? Hahah.. maybe I should have asked before I went ahead and ordered one.
Old Sep 4, 2007 | 08:20 AM
stormcrow's Avatar
stormcrow
wow, i can't believe i didn't see this post... thanks for the kudos, jonathon... and i hope it has completely resolved your issue...
to those wanting to know how it works, i think jonathon did a good job explaining... basically, the oil entering into the plenum reduces the octane of the fuel and this causes the pinging due to detonation... having the catch can filtering out this small amount of oil allows for the fuel to retain its true octane rating and in turn, no pinging...
jonathon added race fuel so that we may know, instantly, whether or not the noise we were hearing was truly pinging... even though we were 99% positive it was, there is always the small chance that it might be another issue... and since we didn't open the plenum to clean out the existing oil, the race fuel gave him a bit of time without pinging while the air cleaned out the rest of the oil in the plenum... luckily, once the race fuel ran out, the plenum was clean enough to not dump any more oil into the intake runners... so, his issue was cured...
Old Sep 4, 2007 | 08:31 AM
athenG's Avatar
athenG
Stormcrow agreed to help me get rid of this knocking sound I was having in my engine. [that's his sweet-looking red Z in the first couple of pics].
He ended up adding this catch can to the hose running from the pcv system to the plenum to catch oil that was getting sucked into the plenum and diminishing my octane rating. (the lower octane rating was throwing off the timing, causing me to have the pinging noise and taking away engine power).
the first image shows the catch can (genius idea) after the install and the next image shows the catch can after my 15 minute drive home from getting the catch can installed. As you can see, I already had oil in the catch can after only a 15 minute ride.
We also added racing fuel to the car and the pinging was completely gone by the time I got back to my apartment.
A big thanks to Jeremy, and I hope this helps anyone else who may be having this same problem.
That is the same compressor filter I got from HomeDepot, they don't sell the old one (the one in the DIY). When I had that Filter, I noticed that there are some air coming out of the bottom especially on Cold start, I didn't like it coz of that hissing sound. Then one day when I was at Autozone, I saw the old filter and bought it and swap it, now no more hissing.
Old Sep 4, 2007 | 08:48 AM
stormcrow's Avatar
stormcrow
i will check out Autozone to see if i can find the older type, as well... thanks for the info... the newer ones are all that can be found at either Home Depot or Lowes... our work-around was to fill the can with epoxy to just above the top of the valve...this sealed it off, so no hissing... but, aesthetically, this is not too pleasing...
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
