drivetrain warranty voided?
Old Aug 25, 2007 | 02:15 PM
Juicehead's Avatar
Juicehead
Default drivetrain warranty voided?
Service dept told me today if I replace my open diff w/ used oem vlsd, it would voide the ol' warranty...
wtf?
Old Aug 25, 2007 | 02:17 PM
zand02max's Avatar
zand02max
yes, its called modification!
Old Aug 25, 2007 | 02:24 PM
Mike Wazowski's Avatar
Mike Wazowski
it would only void the diff
http://www.ftc.gov/bcp/conline/pubs/.../warranty.shtm
GodSendsDeath's Avatar
GodSendsDeath
Ah yes sir, anything not dealer bought and installed should do it. You must always be on the same page as them to be under warranty.
Old Aug 25, 2007 | 02:26 PM
Juicehead's Avatar
Juicehead
yes, but they also told me if I install the Nismo LSD it wiuld still be covered...
Old Aug 25, 2007 | 02:27 PM
zand02max's Avatar
zand02max
they are wrong! Believe S tune or R tune forget which ones ARE NOT covered!
Old Aug 25, 2007 | 02:32 PM
Question
Lets say that you replaced the differential, then had problems with the motor. How does the differential cause motor problems?
Old Aug 25, 2007 | 02:33 PM
zand02max's Avatar
zand02max
They void that portion of the warranty, You know this David!
Old Aug 25, 2007 | 02:35 PM
True. But I wanted the OP to use some common sense here.
Old Aug 25, 2007 | 02:36 PM
zand02max's Avatar
zand02max
I know, I sense the sarcasm,
Dam you have 18K posts now, WTH have I been, lol!
Old Aug 25, 2007 | 02:39 PM
Unlike me - you probably have a life.
Old Aug 25, 2007 | 02:45 PM
genegoesfast's Avatar
genegoesfast
r tune=no warranty s tune=3 yr 36,000(i think)
Old Aug 26, 2007 | 05:49 AM
Q45tech's Avatar
Q45tech
Things directly attached or closely mouunted may not be covered say drive shaft or half shafts as installation of a diff can cause changes or errors in alignment and thus wear of U or rear CV joints bushings or bearings.
If things that don't usually fail in 150k start failing way early after a modification you can't blame Nissan Warranty for try to exclude warranty on things attached to diff.
Sunset350ZR
Nov 15, 2015 05:45 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
