How come no one has the JWT clutch/Nismo flywheel combo?
Old Sep 9, 2007 | 07:50 PM
phorbo007's Avatar
phorbo007
Default How come no one has the JWT clutch/Nismo flywheel combo?
I did a search and was not able to find a single person with this setup. It might not be the lightest setup, but I would think theoretically it should be great for a slight upgrade from stock.
I actually don't mind the heavy stock flywheel, as I can go through stop signs while staying in 2nd gear, even going uphill (due to inertia of flywheel). The Nismo flywheel is a compromise between the lighter JWT (14lbs) and stock (30lbs+?), and being about half the price of the OEM flywheel it's a no brainer.
So what gives?
Old Sep 9, 2007 | 08:02 PM
Mike Wazowski's Avatar
Mike Wazowski
because the JWT flywheel is less expensive and weighs less. Plus it is the perfect match for the JWT clutch.
Old Sep 9, 2007 | 08:03 PM
Devil Z's Avatar
Devil Z
I live in SEATTLE. I go up 70 degree hills with the JWT flywheel.
Old Sep 9, 2007 | 08:07 PM
Mike Wazowski
I have no problems with starting off in 2nd gear or going up hills either.
Old Sep 9, 2007 | 08:11 PM
CC Z33's Avatar
CC Z33
I think PFunk124 has this set up. I met him at a meet a few days ago and I thought he said he has it. Hit him up. He car is set up nicely.
Old Sep 9, 2007 | 08:21 PM
phorbo007's Avatar
phorbo007
Well the price difference is negligible, and the lesser weight is a catch 22. Less unsprung mass you get to rev faster, but the revs drop equally as fast.
Old Sep 9, 2007 | 08:22 PM
phorbo007's Avatar
phorbo007
From a 1-2 mph roll w/o burning the clutch?
Old Sep 9, 2007 | 08:28 PM
Black_Sunshine's Avatar
Black_Sunshine
Just a technical note, that's rotational mass.
Old Sep 9, 2007 | 08:31 PM
yoichi's Avatar
yoichi
I have the JWT Clutch/Flywheel Combo. car feels much lighter and rev matching is much much easier and smoother although gear engagement is a bit rough at times. Great Combo.
Old Sep 9, 2007 | 08:44 PM
Mike Wazowski
my revs dont drop fast and I have had my clutch/flywheel combo for over 40K miles so far and haven't burnt the clutch yet. 20K of those miles have been forced induction pushing over 400whp.
Old Sep 10, 2007 | 01:26 AM
terrasmak's Avatar
Act streetlite would probably be better , and its cheaper than NISMO
juang20
Intake
Sep 7, 2015 05:37 PM
