engine covers
Old Oct 18, 2007 | 12:00 PM
steppinrazor's Avatar
steppinrazor
Default engine covers
i have a v+ plenum in my car, i had to take out the stock cover, it no longer fits ( i knew that before i installed it ) anyways, it disnt look so pretty but ive driven probably 2k miles without a cover... i dont know why i didnt think of it earlyer but, is this bad for my engine?? also, ive found some new covers on the internet but is there a place where i can find some that fit with this plenum top
Old Oct 18, 2007 | 12:07 PM
superchargedg's Avatar
superchargedg
Damn Noobs
You are gonna have to make it fit,i have a aps tall boy plenum and bought a z carbon fiber cover and im gonna have to use a dremel to make it fit.Oh and it will do no damage by running without a cover.
Old Oct 18, 2007 | 05:02 PM
steppinrazor
ok sweet, pretty sure i can figure it out with the stock cover... i checked with the owner of concept z performance here in az and he said theres nothin that will fit yet...
Old Oct 18, 2007 | 06:20 PM
modified350z's Avatar
modified350z
You can make an aftermarket work with a little bit of modification. I have pics of two different covers, and you will see one that is black CF. I had to do some severe modifying on it but turned out. Check out the pics in the linkengine covers-parking-lot-pics-009.jpg
engine covers-engine-003.jpg. But my problem wasnt quit the same but with a little elbow grease you can do it.
Old Oct 18, 2007 | 07:24 PM
steppinrazor
i saw it... thanks man,
and the inside of your car looks pretty sick dude
Old Oct 18, 2007 | 08:40 PM
bbs350z's Avatar
bbs350z
dremel ftw. not like the motor is in plain view 24/7, but im a fan of the engine covers. they make it look neat and clean
Old Oct 19, 2007 | 07:36 AM
gothchick's Avatar
gothchick
Not sure how much diff it makes... But... Heat rises. Why have another layer (engine cover) for the heat to have to dissipate through before transmitting through the aluminum hood? I took my cover off. Did some wire and tube management. Looks clean. Plus things are easier to get to on the engine without the cover in the way.
Old Oct 19, 2007 | 04:26 PM
modified350z
Thanks for the compliment.
Old Oct 21, 2007 | 03:55 PM
halfass872's Avatar
halfass872
Here's a pic of my factory cover with my V+ Took some time with the dremel, but it ended up looking pretty factory! Now the V+ is gone and i gotta try to make it fit around the belts on my Sillen SC!
Old Oct 22, 2007 | 09:28 AM
VO...'s Avatar
VO...
Administrator
+1. Alot of people run without the cover...
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
ablaine
Nov 29, 2016 10:13 AM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
