How do i turn off the check engine light??
Old Oct 20, 2007 | 05:04 AM
halfass872's Avatar
halfass872
Default How do i turn off the check engine light??
I i removed my popcharger yesterday to do some maintnence, and when i put it back i forgot to plug in the mass air sensor. I started the car, realized what i had done, and then pluged it back in. Everything runs fine now, but my check engine light is on. Last time this happened it was on for a few hunderd miles till it turned off. I guess it stays on for a predetermined time or something. I tried disconnecting my battery for like a half an hour, and other tricks?? Thanks!
Old Oct 20, 2007 | 05:44 AM
DavesZ#3's Avatar
DavesZ#3
Try disconnecting the battery and stepping on the brake for a few seconds. If that doesn't do it, leave the battery disconnected overnight.
Old Oct 20, 2007 | 05:46 AM
Vin Diesel's Avatar
Vin Diesel
Who told you that?
Old Oct 20, 2007 | 06:55 AM
halfass872's Avatar
halfass872
anyone else?
Old Oct 20, 2007 | 07:01 AM
It may go OFF on its own.
Old Oct 20, 2007 | 07:03 AM
page04Z's Avatar
page04Z
Originally Posted by halfass872
anyone else?
What DavesZ said will work.
Take the negative terminal off, turn the key on and turn the lights on/step on the brake pedal.
What you are doing is draining all the power completely out of the car. This will "erase" anything the car thinks is wrong. When you start it back up, the car will see the MAF is plugged in and not throw a code.
It SHOULD work.
Old Oct 20, 2007 | 07:07 AM
halfass872's Avatar
halfass872
It SHOULD work.
Thanks!! Gonan go try it now!
Old Oct 20, 2007 | 07:08 AM
KYEXTAZ's Avatar
KYEXTAZ
leave it disconnected overnight
Old Oct 20, 2007 | 07:17 AM
halfass872's Avatar
halfass872
Well i tried the disconnect, key on, brake hold, and that didn't work. SO i did it again, and left it discaonnected. i Have to drive here in a few hours. If it doesn't reset by then, i'll disconnect it when i get it tonite, and leave it off over night.
I'm not going to be in limp mode or anything am i?? Or is it just gonna be an annoyance?
page04Z's Avatar
page04Z
Ok good, I actually had to do this to my car the other night. Tell me the results, if this 5min fix doesnt work then you may just want to leave it disconnected over night like a few people are saying.
And if THAT doesnt work, time to wait it out
Old Oct 20, 2007 | 07:39 AM
halfass872's Avatar
halfass872
Thanks for the help!!
Old Oct 20, 2007 | 10:57 AM
Vin Diesel's Avatar
Vin Diesel
If you take the NEg termial off the battery the car has no juice why do have to turn the key and lights on?
Old Oct 20, 2007 | 11:00 AM
Vin Diesel's Avatar
Vin Diesel
There has to be a easier way than this has anyone google a serach? What does the dealer say?
Old Oct 20, 2007 | 11:19 AM
halfass872's Avatar
halfass872
Could i go to Auto ZOne and have them clear the codes with their code reader?
Old Oct 20, 2007 | 11:36 AM
page04Z's Avatar
page04Z
There is still some power running through the car when you take the terminal off, just watch your odometer numbers fade away as you press the brake pedal a few times.
Old Oct 20, 2007 | 11:41 AM
halfass872's Avatar
halfass872
UPDATE: I removed the negative terminal, did the key/brake thing, and let her sit for about 4 hours. Now all is good, and the light is gone!! Thanks for everyone's help!
Old Oct 20, 2007 | 11:43 AM
__jb's Avatar
__jb
Z + Rear Seat
I wrote a DIY on cleaniing the MAF sensor. Several people forgot to put the MAF back in before trying to start the car.
Leaving the battery disconnected overnight solved the problem for all of them... just like Dave said...
Old Oct 20, 2007 | 11:51 AM
DavesZ#3's Avatar
DavesZ#3
Most electronics systems have a capacitor to hold power when the battery dies or is removed. That keeps all the settings, etc. Pressing the brakes causes the brake lights to attempt to turn on, drawing what little stored charge is left.
loudtoyz
Apr 6, 2023 04:52 AM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
