Use a revup engine on a non revup car
Old Oct 24, 2007 | 03:12 PM
raditz's Avatar
raditz
Default Use a revup engine on a non revup car
A friend has damaged his engine due to oil comsuption. He has a 2003 model and he has found a used revup engine with very low milleage, is possible to mount that engine on his car? it's matter of just use also the revup ECU or it's something else needed?
Any help will be appreciated
Old Oct 24, 2007 | 03:21 PM
saberphx's Avatar
saberphx
I think he will need a standalone EMS. Not sure what else.
Old Oct 24, 2007 | 03:53 PM
raditz's Avatar
raditz
So, it's no possible to use the revup ECU on his car?
Old Oct 24, 2007 | 04:27 PM
Mazinger Z's Avatar
Mazinger Z
Find a HR motor...hmmmm... HR...
Old Oct 24, 2007 | 05:43 PM
9kFever's Avatar
9kFever
the revups are notoriously burning oil. I am on motor number 3! Stay away from the revup!
Old Oct 24, 2007 | 06:40 PM
PDX_Racer's Avatar
PDX_Racer
Too bad for you, maybe it's the driver?
I'm on engine #1, and I autocross mine all over the west coast (and three trips, two of which were towing my little tire trailer behind the Z, to the National Championships in Topeka, KS).
40K miles, no "oil consumption" problems.
As far as the original question, you'll need the engine and ECU -- at least. If you have ABS, you'll probably want the ABS computer as well, since my 2005 doesn't throw ABS codes if I left-foot brake.
Old Oct 24, 2007 | 08:21 PM
9kFever's Avatar
9kFever
Perhaps it could be the driver. It occurs during decel. Nissan is aware of the problem and has released a new motor hand assembled in Japan. https://my350z.com/forum/engine-and-drivetrain/232332-revup-oil-consumption-tsb-and-discussion.html
Old Oct 25, 2007 | 07:52 AM
raditz's Avatar
raditz
I also don't have any oil comsuption on my revup.
About my friend, if he can't use the revup, could use the crankshaft and the rods from the revup only?
Old Oct 25, 2007 | 08:56 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Use the rev-up block, and use everything else from your car. That would be the most straightfoward way to do it.
The block is identical, the heads are nearly identical (just have to plug exhaust cam position sensor hole)
Old Oct 25, 2007 | 12:57 PM
raditz's Avatar
raditz
Thanks sharif!!!!
So he won't have any problem using the short-block from the revup, they are identical, thanks again
Old Oct 25, 2007 | 02:52 PM
Sharif@Forged
Forged Performance
Originally Posted by raditz
Thanks sharif!!!!
that is correct....good luck.
Old Jan 22, 2008 | 05:25 PM
supra crazy's Avatar
supra crazy
What if I have the non-revup harness and ecu with the rev-up motor. Would the car start and run the same? until I get the revup harness and ecu?
etkms
Jun 19, 2022 06:30 PM
nissan1310
Oct 12, 2015 08:54 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Bigsyke
Sep 11, 2015 06:19 PM
