Mod build up question?
Old Oct 30, 2007 | 03:38 PM
LpLove's Avatar
LpLove
Question Mod build up question?
Hey everyone i'm new to the Z world. I just bought an 03 MT Z. As far as mods all i've done so far is a pop charger & magnaflor dual exhaust--suprisingly happy with. I'm looking to with the Crawford Cast Upper Plenum and SKUNK 2 Plenum Spacer for total of $550 from SGP next. I wanted to get everyone's input incase I was wasting money or i'd appreciate any other suggestions for the best performance for a reasonable price nothin outrageous for the moment.
Thanks ahead,
Justin
Old Oct 30, 2007 | 03:51 PM
LpLove's Avatar
LpLove
Failed to mention its a touring
Old Oct 30, 2007 | 03:53 PM
LpLove's Avatar
LpLove
Old Oct 31, 2007 | 06:27 AM
helldorado's Avatar
helldorado
Do one or the other. I don't see how combining them would give you any kind of significant gains, particularly for the price. You could get similar performance and save more than half if you go with one of the Motordyne spacers.
Old Oct 31, 2007 | 07:57 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you would do either a plenum or a spacer as mentioned...I would doubt you could even fit both, nor would both offer any benefit
Old Oct 31, 2007 | 08:24 AM
HondaKiller's Avatar
HondaKiller
As mentioned above, both will not do anything except work against you. I didn't know they still made those crawford plenum's? Anyways, if you use that be prepared to change strut bars, and the same thing with that skunk spacer. Personally i would save a few hundred, get the ISO MD spacer and call it a day. Wont have to replace your strut bar, and you'll gain the same if not more hp.
Old Nov 1, 2007 | 10:44 AM
TENGAI's Avatar
TENGAI
Ditch the Skunk spacer all together. Also, the Crawford is nice, but I'd just go with a MD 3/8th or 1/2in spacer and call it a day...
Old Nov 1, 2007 | 11:52 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
drop that skunk spacer, no one has ever proven gains from it (try to prove me wrong)
Old Nov 1, 2007 | 01:51 PM
helldorado's Avatar
helldorado
The one thing I'm curious about... did SGP suggest this combo to you? Or did you ask for it and that's what they quoted you? Or have you not even approached them about it?
Old Nov 1, 2007 | 10:24 PM
LpLove's Avatar
LpLove
I've just been looking around. Like I said i'm new to the Z world & I would consider myself a hardcord noob and open for any suggestions
I've also been looking into the Nismo R-tune Cams (http://sgpracing-store.stores.yahoo.net/nircavq.html) w/ some tune
Also this looks to good to be true but what do yall think?(http://cgi.ebay.com/ebaymotors/Nismo...spagenameZWD1V)
Old Nov 2, 2007 | 04:47 AM
Z1 Performance
Former Sponsor
you really need to do some heavy searching this weekend in the engine/exhaust threads, etc
cams should be on the bottom of your list to consider for first mods
First round mods:
Exhaust (many styles to choose from, stick to a brand name, to avoid ebay junk)
Intake - the least important thing. Anything from a drop in to a cold air will work, all personal preference...it literally makes 0 difference, don't let anyone tell you differently
plenum spacer - AAM or Hydrazine, both work great, fit great, give immediate gains
test pipes or high flow cats - very little difference between them in performance, significant difference between them in terms of noise. Again, go with what your budget and noise preferences are, and stick to brand names again (no $5.00 ebay junk here either, or you'll regret it, if you get it to work at all)
pulley - optional, but to me, a great mod. Lighter crank at a minimum, full set if you want extra bling. Helps overall engine response, and is an easy install
ecu - once the above are on, get either an ecu flash if you plan to leave the car at it's current state, or a utec if you plan for additional mods in the future.
Old Nov 2, 2007 | 11:50 AM
LpLove's Avatar
LpLove
Well I already have exhaust & Intake,5/16 spacer on order
Old Nov 2, 2007 | 04:22 PM
VIZAGE's Avatar
VIZAGE
Z1 Performance summed it up pretty well for ya. Just take your time and search. That's the only way you will learn to make the most from your car and not waste money on retarded mods. Plan for the future. Something I didn't do. I like to rush to much.
Old Nov 2, 2007 | 06:01 PM
Vader007's Avatar
Vader007
Adam will point you in the right direction, follow his build up, great guy, great shop, great sponser!!!!
Stay off EBAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Welcome to the community.
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Dymsi
Sep 29, 2015 11:32 AM
codek
Sep 28, 2015 03:03 AM
