Nismo Thermostat, HELP!!!
Old Nov 4, 2007 | 09:11 PM
DX USMC's Avatar
DX USMC
Question Nismo Thermostat, HELP!!!
I'm going to swap out my OEM thermostat for the Nismo one tomorrow. My question is that, the Service manual says "Remove water drain plug at the front of the cylinder block" and "Remove water drain plug on water pump side of cylinder block", where are these drain plugs located?
I read the service manual, however, the drawing locations are very sketchy.
Please help!!!
Old Nov 5, 2007 | 02:07 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Now I'm no expert because I haven't done this before, but I don't believe that you need to use the drain plugs on the engine block, as long as you know what you're doing to "burp" the system, get the air bubbles out etc.
Old Nov 5, 2007 | 03:23 AM
Eazzy's Avatar
Eazzy
Just drain your radiator and forget about removing the plugs
Old Nov 5, 2007 | 03:28 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
+1
Old Nov 5, 2007 | 07:32 AM
DX USMC's Avatar
DX USMC
Would that be sufficient enough? I don't want to F up anything.
Old Nov 5, 2007 | 07:34 AM
iStan's Avatar
iStan
ZR
^You'll be fine. Just drain the radiator, install thermostat, fill radiator and go through the burping process.
Old Nov 5, 2007 | 08:00 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
just be 100% sure all the air bubbles are out there is a special way your supposed to do this. If you let sit there and idle and your heater doesnt blow really hot then you still have a air bubble if you can jack up the front of the car when you filling it and fill it very slowly i know it sucks but its the best way if you dont have a coolant evacuator tool.
Old Nov 5, 2007 | 10:06 AM
DX USMC's Avatar
DX USMC
Thanks guys for all the help. I'm gonna go start now. Wish me luck, and I'll let you know what happens.
Old Nov 5, 2007 | 08:02 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by ZU L8R
+1
+2. Drain the rad, remove the lower hose, and r/r the thermo. Eaazzzy.
The harder part, is taking the time to purge the cooling system.
Old Nov 5, 2007 | 09:43 PM
350ZTheStandard's Avatar
350ZTheStandard
Take directions, then u will not fu&k up the quick install, just burp the hoses when you re-add antifreeze to the cooling system. I have read on this site people who have problems with the heater after replacing the thermostat do due not burping the system.
It is just as easy as it sounds..............
Old Nov 5, 2007 | 09:47 PM
DX USMC's Avatar
DX USMC
Thanks for all the help guys. The install went perfect. All systems are normal as usually. Heater works perfect, took me all day to bleed and purge the system.
Old Nov 6, 2007 | 08:58 AM
gothchick's Avatar
gothchick
How did you purge the system? I'm also swapping out my Rad and Thermostat next weekend. In preparation, I found this:
"Do not bleed the air at the radiator. There is a bleeder on the passenger side inline in the hose behind the engine near the fire wall. Run the car and then turn the screw a few turns eventually you will see it bubble until coolant comes out not just air. Close and let run for a couple more minutes and do this again. Repeat as needed."
Old Nov 6, 2007 | 09:09 AM
DX USMC's Avatar
DX USMC
I pretty much went by this DIY that I found... http://crackaddict.com/~flynn/howtos...amco.howto.htm
When you replace the thermostat make sure the gasket sits properly otherwise you will jack up the gasket like I did and have leaks. What I did with the second gasket was that I added very little dabs of RTV silicone sealant to the thermostat so the gasket would stay in place.
Old Nov 6, 2007 | 09:10 AM
Eazzy's Avatar
Eazzy
And run the Heater
iStan's Avatar
iStan
ZR
Congrats. That gasket was as PITA.
Old Nov 6, 2007 | 09:14 AM
gothchick's Avatar
gothchick
Awesome write up! Very informative. Thanks!
And run the Heater.
Will do. Thanks!
Old Nov 6, 2007 | 09:33 AM
DX USMC's Avatar
DX USMC
Here is some pics: the first is what happened to the first gasket, the rest are after install and complete. Enjoy.
Attached Thumbnails Nismo Thermostat, HELP!!!-dsc01929a.jpg   Nismo Thermostat, HELP!!!-dsc01930a.jpg   Nismo Thermostat, HELP!!!-dsc01931a.jpg   Nismo Thermostat, HELP!!!-dsc01932a.jpg   Nismo Thermostat, HELP!!!-dsc01933a.jpg
Old Nov 6, 2007 | 11:18 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Friggen nice (and clean) engine bay!! A work of art!
Old Nov 6, 2007 | 12:20 PM
DX USMC's Avatar
DX USMC
Thanx.
Old Nov 7, 2007 | 09:24 AM
gothchick's Avatar
gothchick
Very clean & professional looking indeed!! :-)
