What is the best clutch replacement for street use?
Old Nov 12, 2007 | 06:27 PM
Spike100's Avatar
Spike100
Default What is the best clutch replacement for street use?
After reading the recent threads about “clutch-slipping,” I have a question:
What is the best clutch replacement (all components) for street use?
OEM Nissan stock?... Aftermarket?... If aftermarket, what are the choices (and, advantages/disadvantages of the available products)?
Please don’t tell me to search. I did that. There is a lot of debate on this, and a lot of the information from a search is old stuff. I’m sure there are new options. The recent discussions here indicate just that. I bet our vendors (a valuable resource on this Forum) have some ideas.
--Spike
Old Nov 12, 2007 | 08:29 PM
eltness350's Avatar
eltness350
The Untouchable
i have the clutchmasters stage 4 clutch/aluminum flywheel...it has a spring hub so it works great on the street but it can hold over 500ft lbs of tq.. easily for drag!!...gl with ur decision....
Old Nov 13, 2007 | 05:04 AM
jonnylaw's Avatar
jonnylaw
How much power are you putting down? Are you NA or FI?
For street use, you should look for organic pressure plate and clutch material for better feel. There are tons of options. "Best" is an opinion: ACT, Fidanza, JWT, etc., plus a ton of jdm offerings (OS giken, orc, exedy, etc).
When replacing the clutch, you should also replace the flywheel. A lightweight flywheel will allow your revs to rise and fall faster, but may also cause a bit of nvh
Old Nov 13, 2007 | 06:25 AM
malized's Avatar
malized
Thumbs up hi
--Spike
hi, hru ? my Z is still stock i was looking for some clutch but after a lot of research i decide to go for ''SPEC CLUTCH STAGE 2+'' It's a very nice clutch also for daily driving and can support >500bhp ...
Old Nov 13, 2007 | 07:47 AM
THE TECH's Avatar
THE TECH
I like my Nismo setup. Drives like stock but can handle plenty hp for most people.
Old Nov 13, 2007 | 07:54 AM
malized's Avatar
malized
Thumbs up
100% BUT can't handle like SPEC or ACT .... but i put SPEC because i should start my new TT project .... BUT IF UR CAR IS N/A so go for NISMO CLUTCH
MY FRIEND have nismo clutch on vortech 400bhp ...
Old Nov 13, 2007 | 08:38 AM
THE TECH's Avatar
THE TECH
Well it just depends on what you are doing. The Nismo can handle what 99% of owners on this forum have.
Old Nov 13, 2007 | 11:12 AM
xav_350z's Avatar
xav_350z
/\ +1
i have the nismo clutch and im happy with my setup.
Old Nov 13, 2007 | 01:39 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
NISMO is nice, a bit grabby, but a nice setup - their flywheel is overpriced and too heavy
I'm partial to ACT - for reasons I've posted many times before
Old Nov 13, 2007 | 01:59 PM
jonnylaw's Avatar
jonnylaw
I luv my os giken STR twin clutch setup. Its sintered bronze and nearly indestructible!
Old Nov 13, 2007 | 03:13 PM
punish_her's Avatar
punish_her
It all depends on what your intentions are. The most common setup is a lightweight flywheel to reduce rotational mass and help rev quicker. The clutch you want depends on your power level and use. Some use organics for NA, Carbon/Kevlar organic composits for midrange mild FI, Multiplate to multiply friction force, Cintered metalics (bronze or iron) for HIGH friction heavy torque high FI.
This isnt a hard fast rule because other factors come into play like sound, engagement, driveability, and the fan boy effect (prefrence of one brand over another).
Best thing to do is sit down and plot out where you want to be and what power you plan on putting out and what you intend to use it for. Then go from there.
I personaly went with the LV5 SPEC 6 puck solid hub clutch with a cintered iron clutch plate and high clamp force. Im using it for multiple application: drag, road work, verry spirited driving. End goal of 600+WHP tune in progress.
Old Nov 13, 2007 | 05:59 PM
Spike100's Avatar
Spike100
Thanks guys. It’s gratifying to ask a question (a thread start) and receive useful responses from some of the most accomplished/knowledgeable members on the Forum.
Here’s my issue: I just hate how slowly the engine revs rise and fall in the Z (I have a stock 2003 Performance model with no performance mods). The slow rpm drop is particularly annoying (Corvette and Porsche do not suffer this complaint). I was blaming this on the engine-design, but recently drove a Z equipped with a Nismo clutch/flywheel replacement, and it was so much better than the stock Z. That is what prompted my question here… thinking the Nismo replacement will certainly work well, but there is probably equivalent and even better aftermarket solutions.
Great responses… I appreciate this. Now I know there are solutions to my problem. Obviously I need to do more research.
And... this last msg. is not meant to be a thread-stop. Any additional comments and advice are very welcome.
--Spike
Old Nov 13, 2007 | 06:12 PM
eltness350's Avatar
eltness350
The Untouchable
do a jim wolf technology clutch/flywheel....affordable and great if u will stay na....
Old Nov 13, 2007 | 06:18 PM
punish_her's Avatar
punish_her
+1
Good for over 400whp easy. I liked the flywheel so much I kept it when I switched clutches.
Old Nov 13, 2007 | 06:21 PM
WSchli1672's Avatar
WSchli1672
Cool
+1 This is what I'm doing, also a friend of mine did the same on his 300ZX TT and felt 10,000 times better than his stock, but also can handle the addtional power, if you decide to build some on your engine. Myself, Vortech S/C and it's plenty for that. I have presently NISMO Header, CAI, and Catback exhaust, which is great to me also. Yes NISMO and JWT are the two ways I look at for most items, but then I'm not a power nut either, so it just depends on your future planning, but both are good and cost effective. When the GTR comes out, then that's another story of course, 2nd year, not first.
Old Jan 9, 2008 | 04:20 PM
team1320350z's Avatar
team1320350z
what do you guys think about clutchmasters stage 3 with act prolite flywheel. i have an 05 z with intake, exhaust, test pipes, kenetix plenum, and want to get 100 shot plus tune my utec. think its a good choice? ive been looking for clutch/flywheel combos fo the past 3 weeks.
Old Jan 12, 2008 | 11:03 AM
eltness350's Avatar
eltness350
The Untouchable
stay with the same brand when u do clutch/flywheel combo...it will save u from a bunch of headaches....
Old Jan 12, 2008 | 11:13 AM
soleil's Avatar
soleil
NolaZcc
not to hijack spike....will the jwt combo handle 400-450hp?
Old Jan 12, 2008 | 11:23 AM
JAM3Z's Avatar
JAM3Z
Phenom
The JWT clutch and flywheel is basically a stock clutch and a Fidanza flywheel. If you want a very drivable setup that can easily handle some big numbers down the road, I say go for the Competition Clutch Stage 4 clutch and flywheel. I have it and i have almost 390whp and it never slips. Its very easy to drive on the street, the clutch is a little more aggressive in nature, but only slightly so. The flywheel is about 13~lbs I believe and with this on the car, the engine revs up much quicker and easier, and drops revs much faster too. Forged gave me a great deal on mine, so it's something I would consider.
JWT is an ok unit, but highly overrated if you ask me, and considering its a stock clutch, I'd say a little overpriced.
Old Jan 12, 2008 | 11:25 AM
JAM3Z's Avatar
JAM3Z
Phenom
Definitely not what I would use with a 450whp setup. I say go for the Carbonetics double or triple plate clutch if you're looking to go top of the line. If you're wanting something a little more affordable, I say go for the Competition Clutch Stage 4 Clutch and Flywheel.
