Auto tranny shifting hard randomly, freakin me out
Old Jan 2, 2008 | 11:39 AM
soshiv's Avatar
soshiv
Default Auto tranny shifting hard randomly, freakin me out
hey guys, for some reason today while i was driving my car about 4 or 5 times it shifted relatively hard... it happened while visiting and driving in a hilly area... it is an automatic transmission and it is worrying me... it seemed totally random and felt funny... only did it about 4 or 5 times though over about a 20 mile round trip so it shifted many many times fine... should i be concerned?
Old Jan 2, 2008 | 11:43 AM
marques1's Avatar
marques1
i think you should be fine usually the transmission will change how hard it shifts depending on your driving style. The harder you drive it the harder the transmission will shift. If you are going up hills its the same as driving the car hard.
Old Jan 2, 2008 | 11:50 AM
soshiv's Avatar
soshiv
it happend totally randomly and is freakin me out
Old Jan 2, 2008 | 12:18 PM
rcdash's Avatar
rcdash
check AT fluid level per the FSM, exactly. any codes or AT light on?
How many miles and when is the last time you had a flush or drain/fill (recommendation is every 2 yrs for flush or every yr for drain/fill)
Old Jan 2, 2008 | 12:32 PM
soshiv's Avatar
soshiv
2003 Touring 45,000 miles.. no engine or a/t lights are on... last drain/refill was done at 30,000 miles
Old Jan 2, 2008 | 12:46 PM
nismo*son's Avatar
nismo*son
mine does that some times when im driving hard/fast
Old Jan 2, 2008 | 12:59 PM
marques1's Avatar
marques1
Im sure your car is fine just make sure you check you trans fluid. Your car is probably just adapting to your driving up and down hills. Drive in manual mode if it bothers you i always drive in manual mode so the trans never gets use to how i drive.
Old Jan 9, 2008 | 12:12 PM
soshiv's Avatar
soshiv
this may sound retarted, but where exactly is the transmission fluid stick to check the level located? I cant seem to find it, am i missing something? It was brought to Nissan last time it was drained/refilled so that is why i dont know where it is located...
Old Jan 9, 2008 | 12:13 PM
iStan's Avatar
iStan
ZR
Against the firewall, Passenger Side. Kinda Round with a 10mm bolt holding it in place.
Old Jan 9, 2008 | 02:03 PM
soshiv's Avatar
soshiv
sweet, thanks bro
Old Jan 9, 2008 | 02:35 PM
soshiv's Avatar
soshiv
just checked it while the engine was cold and it was above the crisscrossed x area.. which i am assuming means it is over filled? I will check it again when the engine is warm
Old Jan 10, 2008 | 02:13 PM
Ilov350ZEE's Avatar
Ilov350ZEE
i need to check mine too, do i need to look under the car? Can point it out where its located?
Old Feb 15, 2008 | 04:49 PM
soshiv's Avatar
soshiv
update: was driving today and the car shifted hard, check engine light came on, and car wouldnt downshift at all it stayed in 3rd or 4th gear for the rest of my trip, after turning car off for a while it is not doing it anymore but it is throwing code P1767 "high and low reverse clutch solenoid valve".. im worried
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
