Dyno rusults from uprev osiris tune
06 G35 sedan 6MT Revup. Mods: Stillen intake, z-tube, motordyne MREV-2 with 5/16 spacer, borla catback exhaust.
Run1 stock with a/c on.
Run 5 was the first good pull on the stock ecu.
Run 20 was the best run tuned.
Props to Jared and the guys over at UPREV in Austin, Tx.
Originally Posted by zyou8er
about 9rwhp?
the peak whp gain is insignificant to the area under the curve gain. area under the curve makes the car more powerful and responsive in everyday driving. peak whp just gives you a higher trap speed on the drag strip.
I was not expecting more than 10hp peak. What I enjoy is what I picked up from 2500 to about 5K. It makes everyday driving a blast. I believe from 2600 to 4000rpm's I picked up from 13 to 16 ft lbs. Also, I went to their shop in Austin so it was less that the $700 that they charge for the online order. The only difference is I dont have the cipher tool. If I need a retune I will just make the trip back to Austin.
