Hose question for engine GURUs
Old Jan 29, 2008 | 04:14 PM
SxExCx's Avatar
SxExCx
Default Hose question for engine GURUs
I am looking to replace some OEM hoses with braided stainless steel ones. The one hose I am not sure about is the one that goes from the side of the upper plenum to into the side of the battery compartment. When I took it off to install the new hose, I noticed it has some sort of regluator in it. If you blow into it, the air will only travel one way. I have seen some engine bays that look like they have just standard hoses connect there. What is this hose/regulator for and what will happen if I use a non-regulated hose?
Old Jan 29, 2008 | 04:56 PM
Corradoslc7's Avatar
Corradoslc7
It would help if you could take a picture of the hose/regulator and post it?
Old Jan 29, 2008 | 09:33 PM
SxExCx's Avatar
SxExCx
I guess it is more of an internal valve than a regulator. There is only one hose where I described, but I will try to find a pic.
Old Jan 29, 2008 | 09:38 PM
SxExCx's Avatar
SxExCx
here...
Old Jan 29, 2008 | 09:59 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Among other things, that provides vaccuum for the brake booster. If you use a non regulated hose, you will lose that brake booster assit if you try and use the brakes immediately after hard acceleration. The valve in there is a check valve, and only lets pressure travel one way
Old Jan 30, 2008 | 08:29 AM
SxExCx's Avatar
SxExCx
can you buy one of those valves and put it in a regular hose?
Old Jan 30, 2008 | 09:36 AM
QuadCam's Avatar
QuadCam
that vacuum hose runs all the way behind the engine compartment and into the brake booster. Make sure you use a check valve on the line if you are going to be replacing it.
Old Jan 30, 2008 | 11:32 AM
SxExCx's Avatar
SxExCx
thanks for the info guys, where can I find one of these check valves?
can it be put into a normal hose?
Old Jan 30, 2008 | 12:40 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Call the dealer and ask for the brake booster check valve.It also might only be sold as the hose assembly......i am not sure about that.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
