JWT C8R cams
Old Feb 19, 2008 | 06:42 PM
  #41
BlackTuner's Avatar
BlackTuner
Originally Posted by Z1 Performance
On a Dynojet, my car would put out higher #'s on a Dynojet, and even higher on a Dynapac
Did you just threaten my dyno? Challenge is on...
p.s.
Everyone I am joking...
Old Feb 19, 2008 | 06:45 PM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
nice! We'll get it down there soon, I want a "Black Tuner" map on my laptop because it sounds like a cool mod to have
a built HR would be sweet to see...someone should do it!
Old Feb 19, 2008 | 06:47 PM
  #43
Z1 Performance
Former Sponsor
Originally Posted by gothchick
I'm debating on a 3.8L non-sleeved stroker build. Not sure if the extra $5K ~$6k for a 3.8L build over a 3.5L build is worth it though... Can't wait to see Kwame's stroker build when it's finished.
Erin - why would a non sleeved 3.8 cost so much more?
Old Feb 19, 2008 | 08:47 PM
  #44
thawk408's Avatar
thawk408
I would guess, because in order to use the 96mm piston you need the GTM or BC crank?
Old Feb 19, 2008 | 09:01 PM
  #45
1cockyZ's Avatar
1cockyZ
within the next 60 days I will have my new engine together. BC 264's and wiseco/eagle rods pistons. I just want something to hold together on track days. A wiseman said something very interesting to me a long time ago "Race cars don't need vtec". What he meant was that you pick your rpm range you want to make power and choose your cam.
Old Feb 19, 2008 | 09:06 PM
  #46
thawk408's Avatar
thawk408
Thats kinda hard on new cars these days. The software will ultimatley decide where most the power is.
Old Feb 20, 2008 | 10:03 AM
  #47
gothchick's Avatar
gothchick
Kyle at Import Parts Pro has a nice head package:
Stage 3:
Notes:
Choice of Upgraded Cams
Ferrea Oversize Intake and Exhaust Valves
Ferrea Heavy Duty Valve Springs
Ferrea Titanium Retainers
Ferrea Valve Spring Locators
Ferrea Valve Locks
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
5 angle radius cut valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for stock cams
Heads prepped and assembled
Old Feb 20, 2008 | 10:12 AM
  #48
__jb's Avatar
__jb
Z + Rear Seat
NISMO VTC pullies may still be gettable depending who you know. Last set we got we were told it was the last set they had, but who knows. I don't have them, nor will I be using them as I don't want to rip my heads apart just to install them. We have them going on kwame's car because his cams (Tomei 280) necessitate them.
Does VTC stand for Variable Timing Control? I'm assuming (dangerous) that these are adjustable timing gears that let you adjust the camshaft timing.
In my small block Chevy racing days, a camshaft Designer would tell me where to install a new camshaft. We called it "Degreeing" the cam. I would find TDC of the piston and then TDC of the camshaft lobe and insert an offset bushing in the timing gear so that the cam was aligned per the designers specifications. Is that what we are talking about here?
How do cams necessitate needing VTC?
  #49
gothchick's Avatar
gothchick
I'm not sure exactly... Maybe because GTM doesn't refund a core charge. I haven't asked them yet...
The GTM non-sleeved stroked short block is $6,600 + additional $$ for other little things that come up.
Kyle at Import Parts Pro has a nice complete 3.5L short block for $2,600 (after core refund).
Including:
-Wiseco Pistons .020 over
-Eagle Rods
-ARP Rod Bolts
-Block inspected and cleaned
-Block redecked
-Block Bored and Honed using a Torque Plate
-Rotating assembly balanced to 50%
-Crank magnafluxed and the journals micro-polished
-New Moly coated Race Spec main bearings installed
-New Moly coated Race Spec rod bearings installed
-Block prepped and assembled
The difference on paper is only $4k, but I was also factoring in a "fudge factor" for a stroker build...
Old Feb 20, 2008 | 10:34 AM
  #50
ke0ki2k's Avatar
ke0ki2k
hey black tuner when are ya droppin the C8R's in?
Old Feb 20, 2008 | 10:38 AM
  #51
Z1 Performance
Former Sponsor
yes that is correct
some cams will "need" more adjustment than even the stock vtc pullies allow for to maintain good idle and a broader power band...cams with more extreme durations and ramp angles.
Erin - you could do sleeves and 100mm pistons and end up at a 3.8 liter as well, using a stock crank. Again, you can certainly gain the extra cc via altering stroke too, it just depends what you want. Unless you are going for a more extreme NA build, you wont really derive much benefit from oversized valves IMHO..except alot more expensve. Also, give Head Games a call too....if I didn't have my own guy for all our stuff, that is who I would use to build the head. As for the block, I'd simply get the components and have a machinist local to you do it....much easier to go this route should a problem arise down the line IMHO
  #52
Z1 Performance
Former Sponsor
patience..when he gets them, he'll install them...
Old Feb 20, 2008 | 10:43 AM
  #53
Z1 Performance
Former Sponsor
VTC and VTEC are completely not the same thing...you do realize this right?
Old Feb 20, 2008 | 01:25 PM
  #54
__jb's Avatar
__jb
Z + Rear Seat
yes that is correct
Thanks, Adam.
Old Feb 20, 2008 | 02:46 PM
  #55
ke0ki2k's Avatar
ke0ki2k
<-- most impatient person ever.
Old Feb 20, 2008 | 03:42 PM
  #56
Nathan's Avatar
Nathan
Wiseman is correct for a race car, a dedicated race car will have enough gear ratios & the final drive selected to keep the motor with in the sweet spot range. The more exotic & powerful a motor gets for a given capacity the smaller the sweet spot.
Broadly speaking inlet valve opening position is more important than inlet valve closing position for making power in the lower to midrange. Inlet valve closing is a lot more important in high revs.
VTC allows a bit of the best of both worlds.
But lets get back to the topic of JWT C8 cams.
In the static position (phasers off ) the inlet valve opens at 13 deg BTDC & closes 79 ATDC for a total duration of 272 deg. Remember this is adv duration.
@ .50" where measurable flow starts, the inlet valve opening will be at ATDC with phaser off & this is where the OE ECU has placed the cam at just over 6k.
Now I dont believe that this is the sweet spot for this cam @ 6 to 7.5k
As more NA motors are tuned by the Haltech platinum or others we will soon find out.
Old Feb 20, 2008 | 04:03 PM
  #57
BlackTuner's Avatar
BlackTuner
I haven't received them yet. Although I am working on a side project that will compliment my cams very well on a HR.
I have some ideas for alternative vtc control on the intake and exhaust cams that may work out too. I may even play with it before I get the cams in the car to see what can be done.
Old Feb 20, 2008 | 05:39 PM
  #58
rednezz's Avatar
rednezz
Nathan, do you know if you can adjust the VTC angles past 6600 rpms on the non-revup motors? When I was tuning my car at UpRev they told me the even though they were adjusting the VTC angle past 6600 rpm it wasn't actually changing past 6600 rpm.
I discovered for my car with the Tomei 272 cams I needed about 8 to 10 degrees past 6200. I wouldn't be surprised if the JWT C8 cams would need around the same VTC angle. I think it would be a good ball park to start with.
Old Feb 20, 2008 | 08:03 PM
  #59
Nathan's Avatar
Nathan
No I don't no what can be done with a reprogram with regards to cam phasing. We dont have anyone here in Oz that has the software.
What I do know is that the stock ECU only changes the lobe centre of the inlet cam from retarded 125 deg to advanced 90 deg a total of 35 deg. But the VTC sprocket has a full 20 deg range of movement which = 40 deg @ the crank. ( I've measured it )
HKS with Valcon plus cam kit advertise that they get an extra 5 deg of advance over stock & they don't change the sprockets. I would assume they get it electronically but maybe they grind the lobe centers with 5 deg advance but I wouldn't think so.
The Nismo S2 dealer program advertises the VTC increased from 40 to 50 deg but I dont know if it includes a new ECU or a reflash.
At 6600 + rpm you would certainly not want a inlet cam lobe centre @ 125 deg
Between 10 to 15 is probably a good start point & that makes the lobe center now 115 to 110
I hope Black Tuner does get something to work with the Utec as I don't want to buy another ECU
Old Feb 20, 2008 | 08:05 PM
  #60
ke0ki2k's Avatar
ke0ki2k
what all ya got done to push 294 rwhp red?
