How do u remove the silencer from Greddy Ti-c
Old Feb 17, 2008 | 07:22 PM
zyou8er's Avatar
zyou8er
Default How do u remove the silencer from Greddy Ti-c
i bought this exh for my brother new, and the silencer does not want to come out, any ideas? Thanks.
Old Feb 17, 2008 | 07:24 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
there are 3 small bolts on the tip that will need to be unscrewed, the silencer just slides out. make sure you get the exhaust installed with a spacer or modify the hangers so you don't get your bumper burned like mine did and the rest of the comunity.
Old Feb 18, 2008 | 11:19 PM
zyou8er's Avatar
zyou8er
Thanks, i tried to remove the silencer with the screws and tip removed, but that thing is in there tight, i used wd40 and it still does not want to come off, on the bumper note we just folded the center and used self taping screws to hold it, Thanks for replying.
E
Old Feb 18, 2008 | 11:22 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Get a couple of vice grips and put a towl over the little pipe the gases escape out of (not the bell shaped part). Clamp opposite sides with the vice grips over the towel on the pipe and pull out. I had this problem with a topspeed exhaust before (left exit) and this method worked all the time. It'll never "fix" itself, though, so carry the tools around.
Putting it in is also a b1tch. You need to put them in, but you have to align it just right for the holes to land. At a certain point, you won't be able to put it in without messing up the alignment. Just get the holes to kind of match up, then use a thin flat head and move it all around to get the holes to line up.
Old Feb 19, 2008 | 02:55 AM
zyou8er's Avatar
zyou8er
Thanks again, one more quick question. Having the silencer on, will it kill HP? Thanks.
Old Feb 19, 2008 | 09:03 AM
3hree5ive0ero
Retired Admin
You lose power from mid range to the top, but you'll gain a little bit of torque in the lower RPMs.
I only took out the silencer to race at the track. Otherwise, I always left it on since the Topspeed exhaust was way too damn loud.
Old Feb 19, 2008 | 11:01 AM
zyou8er's Avatar
zyou8er
So, its best to remove the silencer correct? sorry for asking so many ?s dont know much about the 350z much, Thanks again.
Old Feb 19, 2008 | 11:07 AM
jumpin800agl
8 to 11
i removed mine after a few days and never looked back. I thought the sound was better plus the power gains.
Old Feb 19, 2008 | 12:21 PM
3hree5ive0ero
Retired Admin
You will have more overall power/torque with the silencer out. The sound is subjective, so that's all on you (with silencer in or out).
Old Feb 19, 2008 | 06:21 PM
zyou8er's Avatar
zyou8er
Thanks for the reply guys, people like you make the difference. Once again Thanks.
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
