belt question, need answer asap
Old Apr 17, 2008 | 04:49 PM
andyisphat2004's Avatar
andyisphat2004
Default belt question, need answer asap
One of my belts squeels when i first start up the car for the first 20 seconds or so. Does this generally mean the belt is too tight or too lose. I would assume too tight since it stops once it is warm. I dont think it is a pulley problem.
thanks
andy
Old Apr 17, 2008 | 04:54 PM
Sean's Avatar
Sean
check to see if your belt is slick with humidity before you start it.
I know what you are thinking about the belt being tight and than expanding, but the pulleys start "small" and heat / expand, thus tightening the belt, that is what I think is the case for you unless you find the belt is wet with your tropic humidity.
Old Apr 17, 2008 | 04:57 PM
andyisphat2004
maybe, but it didnt start dooing it until i changed them. different type of belt maybe. Sucks i cant guess and check because it only does it for such a short period of time.
Old Apr 17, 2008 | 05:11 PM
Sean's Avatar
Sean
feel like it has play when you first touch it cold, than tight after it has been running?
Old Apr 17, 2008 | 05:17 PM
Spike100's Avatar
Spike100
Andy,
I’m guessing here, but I don’t think it is belt tension causing this problem. I suspect (but again, I’m guessing) that one of the pulleys (air conditioner pump, alternator, etc.) is sticking. When the belt runs for awhile, the offending component releases and the squeal goes away.
Check the pulleys for one that might be sticking.
--Spike
Old Apr 18, 2008 | 10:06 AM
Zmonster24's Avatar
Zmonster24
When I first installed my UR underdrive pulley and new belt, my belt did the exact same thing. New belts will stretch soon after installed. I tightened it and have never had a problem with it since.
Old Apr 20, 2008 | 04:51 PM
mark cooke's Avatar
mark cooke
sounds like you have cheap (autozone?) belt.get a nissan belt($11or$12)problem solved.never overtighten belt,you will brake pulley ***. mark
Old Apr 20, 2008 | 04:52 PM
surfcity40's Avatar
surfcity40
too loose le trek? sry, drinking.
Old Aug 13, 2008 | 11:58 PM
hangookeh's Avatar
hangookeh
actually, autozone has better belts than the dealership, as the oem ones are just stock belts made from nissan. Autozone does sell poor quality belts, but if you buy the right one from them, it beats the nissan stocks. For example, try the gater-backs sold at autozone, quiet as hell, more preferable and reliable than the oem stock belts sold from nissan.
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Nov 9, 2015 11:10 AM
