Oil Pan Bung - Oil Temp Sensor Mount
Old May 12, 2008 | 06:04 AM
JasonZ-YA's Avatar
JasonZ-YA
Default Oil Pan Bung - Oil Temp Sensor Mount
Hi,
I just recently had a local machine shop make and install (weld) this bung for me for my oil temp sensor...thought i would share the pic's.
For you Texas people he is located in the Dallas/Fort Worth area and only charged me 30 bucks to make and install and tap for 1/8 NPT oil temp sensor sending unit.
pm me if you want the companies info.
OEM STOCK PAN BOLT HOLE.
Size 12mm-1.25
PLAN ON BUYING THIS NEXT - http://www.quickoildrainvalve.com/
- Jason
Attached Thumbnails Oil Pan Bung - Oil Temp Sensor Mount-img_4148.jpg   Oil Pan Bung - Oil Temp Sensor Mount-img_4149.jpg   Oil Pan Bung - Oil Temp Sensor Mount-img_4150.jpg   Oil Pan Bung - Oil Temp Sensor Mount-img_4151.jpg   Oil Pan Bung - Oil Temp Sensor Mount-img_4152.jpg
Old May 12, 2008 | 07:30 AM
gothchick's Avatar
gothchick
Nice!
Old May 12, 2008 | 07:33 AM
JasonZ-YA's Avatar
JasonZ-YA
ya...he did a good job..he did a cold weld from the inside and he didnt apply any heat so that the pan wouldnt warp and loose its matting surface flushness.......
- J
Old May 12, 2008 | 07:34 AM
JasonZ-YA's Avatar
JasonZ-YA
Hey, does anyone know what RTV sealant is needed and what the torque values are for reattaching the pan? is there a install/torque sequence - criss cross tightening pattern??
- J
Old May 12, 2008 | 08:14 AM
gothchick's Avatar
gothchick
Here ya go...
EM-34 from the FSM. Has RTV recomendations, torque, and tightening pattern. Try saving this page to your hard drive, then you can focus in better when opening it up.
Old May 12, 2008 | 09:37 AM
JasonZ-YA's Avatar
JasonZ-YA
thanks so much gothchick.....i plan on going only NA UTEC on my car like yours...seen your threads a love your TXS tuner install..
- J
Old Sep 12, 2008 | 10:00 AM
rrmedicx's Avatar
rrmedicx
FYI. With regards to the oil drain plug mod...Bought it. Not worth it IMHO. If you look closely you will notice that the new fitting fits the size of the drain plug and the opening in the new device is at least 1/2 the size of the original opening which means that less can come out of the drain than previously.
So in essence it takes longer for the same amount of fluid to drain as it did before. I thought it would help tremendously with regards to the 'tool-less' oil change, but in fact it makes it longer, since I have to wait longer for all of the fluid to drain out.
Not a bad idea overall, but the narrow opening makes it take longer to empty the oil pan.
Going back to original drain plug.
Old Sep 12, 2008 | 10:05 AM
mikez97's Avatar
mikez97
i have mine the oil drain valve and i need to re seal it but i have an extra if you were looking to buy?
Old Sep 12, 2008 | 10:39 AM
coachk's Avatar
coachk
Are you referring to the Fumoto??
Old Sep 12, 2008 | 10:56 AM
rrmedicx's Avatar
rrmedicx
Yup. It stinks. Oil basically drips out...instead of pouring out as it should.
Last time I tried to wait for the oil to fully drain, I opened up the valve, went to lunch, came back and it was still dripping out.
Nuf said.
Old Sep 12, 2008 | 11:12 AM
gothchick's Avatar
gothchick
I had the Fumoto for about 1 oil change, then ended up going with this instead. Lol~
Old Sep 12, 2008 | 11:23 AM
coachk's Avatar
coachk
Well I guess there is a trade off....Taking the APS drain plug in and out every 2-3k takes its toll and eventually it strips. I have nothing but time so if it takes overnight to drain then oh well
I haven't had to change my oil yet with the Fumoto, but its coming up real soon
Old Oct 28, 2008 | 12:41 PM
JasonZ-YA's Avatar
JasonZ-YA
^^ how did it go??
-j
Old Oct 28, 2008 | 02:32 PM
coachk's Avatar
coachk
Originally Posted by JasonZ-YA
^^ how did it go??
-j
Funny you ask...I'm changing the oil for the first time on my built motor tomorrow. Going to race Thursday night so doing some little tweaks to it while its on the lift.
Old Oct 28, 2008 | 06:07 PM
JasonZ-YA's Avatar
JasonZ-YA
pics of lift......lol
i want one so bad...
Old Oct 29, 2008 | 05:16 PM
coachk's Avatar
coachk
As requested also the Fumoto doesn't take that much longer to drain and no worries about stripping the pan
Old Oct 29, 2008 | 05:29 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
coach, you have your own two post lift?
Old Oct 29, 2008 | 06:38 PM
coachk's Avatar
coachk
Actually have 2 lifts..the other one is in the background in the pic.
Old Oct 29, 2008 | 07:57 PM
JasonZ-YA's Avatar
JasonZ-YA
sweet! you have your own shop?? company?
im planning on buying a lift for my residential garage......lol....
-j
Old Oct 30, 2008 | 08:10 AM
coachk's Avatar
coachk
No its my buddies shop,he just lets me use one of his lifts
