What year VQ?
Old May 16, 2008 | 03:51 AM
gregfarz78's Avatar
gregfarz78
Default What year VQ?
I bought a used VQ35 engine he told me its from a 04 Z is there any way to tell for sure what year it is maybe by a serial number on the engine somewhere?
Old May 16, 2008 | 05:35 AM
gothchick's Avatar
gothchick
Non revup = 03-04 MT
Non revup = 03-06 AT
Revup = 05-06 MT
HR = 07-08 MT & AT
To the OP's question. It probably doesn't matter what 'year' the motor is (as long as it isn't an HR). Just do a compression check on it and general inspection and you should be fine.
Old May 16, 2008 | 06:40 AM
gregfarz78's Avatar
gregfarz78
I think it does matter what year I'm dropping this into my S13 and I need to use the ECU from the same year as the engine
Old May 16, 2008 | 11:41 AM
gothchick's Avatar
gothchick
Ahhh, since you're doing a conversion, you might wanna check this out.
https://my350z.com/forum/na-builds/350513-vq-powered-s14.html
FYI, The bottom ends are all the same. Only the heads changed from the non-revup to the revup. Not sure about the compatibility matrix for ECU's though...
Old May 16, 2008 | 06:36 PM
jpo's Avatar
jpo
Sorry to hijack your thread with a noob question but what's the difference between a non-revup & revup engine? As in is "revup" a bonus or a drawback, or just another way they made them?
Old May 19, 2008 | 06:33 PM
gregfarz78's Avatar
gregfarz78
https://my350z.com/forum/showthread.php?t=350513
ah thanks I actually saw that thread and talked to that guy a few times, mainly I'm concerned about the compatibility with the ECU I want to buy the correct ecu/bcm for the engine I have. The serial I pulled off the engine is 642503A-VQ35 if anyone can tell me what that means or what year I'd appreciate it
Old May 19, 2008 | 07:16 PM
nismo240r's Avatar
nismo240r
I think you'll need the vehicle's VIN in order to determine which year it was. . .
The difference between a non revup and a revup is the heads.
The revup has both intake and exhaust cam timing, a higher redline, higher horsepower but less torque. You can tell by looking at the heads, you'll see 2 sets of circles on the front of each head where the cams are. CR, bore and stroke are the same for both engines.
Non rev ups have a single circle on each of the heads. . .
Determine which engine you have first, then get the matching ecu. . .
not sure if you could use a revup ecu on a non revup vq without throwing codes. . .
Old May 20, 2008 | 04:04 AM
gregfarz78's Avatar
gregfarz78
Pretty sure its a non-revup so its a 03 or 04? I just didn't know if I could use 03 or 04 ecu or not or if it had to be the same exact year as the engine. I won't be able to get the vechile VIN it was pulled from a wrecked Z and I bought it off someone second hand.
Old May 20, 2008 | 04:16 PM
nismo240r's Avatar
nismo240r
^^ yep that's a non-revup, just need an ecu for that type. . .
man i've got to clean up my engine bay. . .yours is looking good!
Old May 20, 2008 | 05:15 PM
gregfarz78's Avatar
gregfarz78
Ok great...the guy I bought the car from pressure washed the engine bay and underbody
Old May 20, 2008 | 06:36 PM
Hoooper's Avatar
Hoooper
the year doesnt matter, you just need to get an ECU for a non revup z and it will work
Old May 21, 2008 | 05:50 AM
gregfarz78's Avatar
gregfarz78
the ecu, bcm, and nats have to all match up though right?
Old May 21, 2008 | 07:25 AM
gothchick's Avatar
gothchick
^^^ Correct.
Old May 26, 2008 | 03:39 AM
jpo's Avatar
jpo
What's a BCM? (Not brake master cylinder obviously!)
Also matching these up doesn't apply to aftermarket standalone ECUs like the Haltech, right?
Old May 26, 2008 | 09:57 AM
gothchick's Avatar
gothchick
Body control module
Old May 26, 2008 | 01:53 PM
jpo's Avatar
jpo
What does that do do you mind me asking?
Old May 27, 2008 | 05:08 AM
BrazenZ's Avatar
BrazenZ
Revup = 05-06 MT
HR = 07-08 MT & AT
I own an 05 mt in a base model and it is a Non revup motor.
Old May 27, 2008 | 10:07 AM
gothchick's Avatar
gothchick
It does everything that the ECU doesn't do:
Windows
Locks
ABS
TCS
Cruise
Climate
Anti Theft
etc...
Old May 27, 2008 | 10:23 AM
gothchick's Avatar
gothchick
You should have another look. If you truly have a non-revup in an 05, then you don't have MT, you'll be AT.
Dat's jus how Nissan rolls yo.
Here's what they look like:
Old May 27, 2008 | 10:56 AM
PDX_Racer's Avatar
PDX_Racer
More than the heads changed -- the non-RevUp ECU will throw ABS codes when left-foot-braking. The RevUp ECU does not.
