is JWT clutch same as stock?
Old Jun 8, 2008 | 03:33 PM
SlideWays314's Avatar
SlideWays314
Default is JWT clutch same as stock?
I just received my JWT clutch and I see that the disc is made by Exedy, which is what is used the the stock 2006 350Z's. The clutch cover also looks exactly like OEM. Is there even a difference?
Old Jun 8, 2008 | 05:07 PM
lionheartednyhc's Avatar
lionheartednyhc
um yes.
Old Jun 8, 2008 | 06:13 PM
GTM's Avatar
GTM
Vendor - Former Vendor
The JWT clutch is the same as stock with a modified pressure plate for higher clamping load.
This is why some hold more power than others. Since they are all modified, they don't all hold the same power.
-George
Old Jun 9, 2008 | 02:22 PM
bimmertech's Avatar
bimmertech
are you sure your 06 has an exedy disc?
pretty sure mine was a LUK.
Old Jun 9, 2008 | 02:52 PM
Motormouth's Avatar
Motormouth
I thought only the 03-04 had Exedy. when I bought a stock replacement it was a LUK. and it SUCKED. lol
Old Jun 9, 2008 | 03:14 PM
bimmertech's Avatar
bimmertech
mine was for sure a POS.
30k miles, plenty of material left but would slip fairly regularly.
dunno if the stock clutch hose had a delay valve or the self adjusting pressure plate sucked, but the jwt clutch is 10x better.
Old Jun 10, 2008 | 04:20 AM
ColoradoClark's Avatar
ColoradoClark
For those of you that are saying that the JWT is basically a modified OEM clutch, what would you recommend instead of the JWT? I don't have any plans on FI for my 2007 Nismo, but I do plan to track the car 4-5 weekends a year -- and I am not very happy with the stock clutch.
Old Jun 10, 2008 | 04:53 AM
JasonZ-YA's Avatar
JasonZ-YA
stick with the JWT! i track my car way more often than that and that clutch is spot on reliable........i know exactly when its engaging!
2nd best mod over my suspension..
- j
Old Jun 10, 2008 | 04:55 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
as of right now the JWT is the only clutch out for an 07 that I am aware of.
Old Jun 10, 2008 | 07:40 PM
GTM's Avatar
GTM
I never said the JWT was a bad clutch kit, just answering the questions about it being the same as stock.
I would run a JWT clutch kit, or if you don't want the flywheel chatter that the JWT kits have go for the Exedy Stage 1 kit for our cars.
-George
EnjukuRacing
Sep 30, 2015 06:55 AM
