Water Temp Adapter Question
Old Jun 13, 2008 | 10:37 AM
JasonZ-YA's Avatar
JasonZ-YA
Default Water Temp Adapter Question
Hi,
i bought the greddy water temp adapter pictured below? Am i supposed to hook up a ground on this thing somewhere in the engine bay?
There is no screw mount for a ground anywhere?
- J
Old Jun 13, 2008 | 02:27 PM
gothchick's Avatar
gothchick
Ground? No.
Old Jun 18, 2008 | 10:10 AM
JasonZ-YA's Avatar
JasonZ-YA
HUMM?? okay well then i dont know what's wrong with my set up??
I installed the greddy water temp on the rad hose and ran the wire to the gauge! gauge works, well lights and stuff.
i even disconnected that gauge and tried an identical 2nd on i had? STill no worky??
any idea's?
- j
Old Jun 18, 2008 | 10:44 AM
Hoooper's Avatar
Hoooper
im not even sure what the question is.
Old Jun 18, 2008 | 11:42 AM
SpoilsofWar's Avatar
SpoilsofWar
You dont ground the adapter... You ground the temp sensor, yes. One wire to the guage, one wire to ground. I used the engine.. The timing cover to be exact if I recall.
Where did you mount this? Upper radiator hose?
Old Jun 18, 2008 | 11:44 AM
JasonZ-YA's Avatar
JasonZ-YA
yes, upper radiator hose..
darn, so im gonna go try this when i get home....
so from the sensor mounted on the greddy adapter i have to have two wires coming off the sensor, one to ground, one to the gauge?
- J
Old Jun 18, 2008 | 11:54 AM
Hoooper's Avatar
Hoooper
ohh i get the question. yeah you have to have two wires from the sensor. since the sensor isnt grounded by contact, you need a wire to get there. if it isnt grounded you wont get any current through the wire, so the gauge wouldnt register any temp
Old Jun 18, 2008 | 11:55 AM
JasonZ-YA's Avatar
JasonZ-YA
SWEET! cant wait to get home and fix it...
Old Jun 18, 2008 | 11:57 AM
SpoilsofWar
You got it. Since you used the upper radiator hose, you can use that existing ground point on the passenger side of the timing cover to ground your temp sensor, its close and convenient.
Old Jun 18, 2008 | 12:00 PM
JasonZ-YA's Avatar
JasonZ-YA
awesome
Old Jun 18, 2008 | 12:08 PM
Hoooper's Avatar
Hoooper
gl to you, enjoy that new gauge. glad it was an easy fix
Old Jun 25, 2008 | 04:29 AM
JasonZ-YA's Avatar
JasonZ-YA
Default still no worky??
okay,
Im guessing now my gauge must be broken??
I hooked up two wires as shown in the picture, one to the gauge and one to the existing engine ground right next to the engine cover but the gauge still doesnt work?
any ideas?
- J
Old Jun 25, 2008 | 06:23 AM
rcdash's Avatar
rcdash
^ you are grounding out your signal. place the black lead lower on the body of the sensor. you can use a small hose clamp and bare wire to get a good ground signal from the BASE of that sensor to the chassis.
The top portion of a temp sensor is electrically isolated from the bottom part. You need one wire going to the top (central) portion of the sensor and the other wire going to the lower (outside) part of the sensor. The sensor is just a variable resistor.
Old Jun 25, 2008 | 06:49 AM
JasonZ-YA's Avatar
JasonZ-YA
aaahhh...darn....i see..
Old Jun 25, 2008 | 07:24 AM
zdatsun's Avatar
zdatsun
You can ground the unit from the back of gauge to any good ground source within the vehicle. The only wire attached from the sensor itself is the one that actually goes to the sensor port on the gauge. There should be a separate connector port on the rear of the gauge for ground only and one for lighting.
Old Jun 25, 2008 | 07:26 AM
Hoooper's Avatar
Hoooper
yeah, rcdash has got it. normally, the sensor would be grounded through the threads but because its on a hose you have to wire the threads to a ground, which is exactly what rc said
Old Jul 16, 2008 | 05:56 PM
ekan350's Avatar
ekan350
Yep, never trust the stupid factory gauge! That OE gauge won't go up until the temp reach to ~250. That's exactly what I want to do next!
Does anyone know the size of the Greddy's adapter? Also, where do you guys get the 12V power source and the lighting source?
Old Jul 17, 2008 | 08:04 PM
JasonZ-YA's Avatar
JasonZ-YA
i got to look up the greddy size, i cant remember....
but for power i used empty spots from the fuse box...i used an "add a fuse". see pic...
-J
Old Jul 18, 2008 | 01:32 AM
ekan350's Avatar
ekan350
Good idea to use "add a fuse"
How about the lighting source?
Thanks
Old Jul 6, 2009 | 06:58 AM
mw9's Avatar
mw9
Originally Posted by JasonZ-YA
Hi,
- J
what size did you get and what gauge are you running?
