Question about changing clutch fluid
Old Jul 24, 2008 | 10:29 AM
pony_killer's Avatar
pony_killer
Arada ninda apa
Default Question about changing clutch fluid
Well I just purchased some Motul RBF600 from Sharif but I have no idea how to change the fluid...is there a how to out there or can anybody tell me? Also is 1 bottle enough? I figure next weekend I'll change the clutch/tranny/diff fluids all at once. Just need a how-to for the clutch fluid...thanks in advance.
Old Jul 24, 2008 | 11:08 AM
terrasmak's Avatar
Did you get the braided line too, may as well if your changing the fluid. Also , have you ever bleed brakes ? If you have , its the same way , you have a bleed port on the slave.
Old Jul 24, 2008 | 11:17 AM
pony_killer
Arada ninda apa
no i didn't purchase a braided line...didn't feel i need to until i replace my clutch. ive never bleed brakes before either so i have no clue. the only thing ive done before is change the diff fluid at 15k miles.
Old Jul 24, 2008 | 05:31 PM
terrasmak's Avatar
My suggestion, look in the regional section and find someone in your area who can help you do it. Its a simple job, but you can easily screw up while learning.
Old Jul 24, 2008 | 06:30 PM
SuperBlack350z's Avatar
SuperBlack350z
if you are familiar with bleeding brakes, it's the same thing. Have a person sit in the car pumping the clutch while you are loosening and tightening the bleeder valve under the car.
Old Nov 24, 2008 | 10:57 PM
350POWER's Avatar
350POWER
what is braided line? does it necessary need to replace when bleeding the clutch fluid? what happen if dont replace it? tks
Old Nov 25, 2008 | 07:14 AM
t0mills's Avatar
t0mills
Definitely get the braided line before you do this. It replaces the OEM rubber line, that runs from the slave cylinder to the hard line on the chassis. It's only about 8" long or so, but does make a big difference.
If you do the line now, you won't have to drain your clutch fluid and re-bleed when you install your clutch. You can just set the slave cylinder out of the way.
-Tim
Old Nov 25, 2008 | 07:26 AM
JasonZ-YA's Avatar
JasonZ-YA
Might i suggest the FSM (FACTORY SERVICE MANUAL)
YOU CAN CLICKY HERE: http://www.nicoclub.com/FSM/350Z/
SEE SECTION CL - CLUTCH FLUID - BLEED
Attached Thumbnails Question about changing clutch fluid-bleed-clutch-fsm.jpg
Old Nov 25, 2008 | 07:28 AM
JasonZ-YA's Avatar
JasonZ-YA
oh, and these are kinda nice......if you dont have a buddy available to help...
-j
http://search.harborfreight.com/cpis...eder&Submit=Go
SonnyWu
Nov 24, 2015 08:19 PM
bcoffee20
Nov 19, 2015 06:39 PM
Ace2347
Sep 22, 2015 03:12 AM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
