Perfect Power ECU update!!! WOW !!!
Old Aug 13, 2003 | 07:50 PM
  #161
Juztin's Avatar
Juztin
I'm up high elevation wise, so I would probably end up needing to custom tune. My car is running really rich up top in the power band, so much so that if I put spark plugs in the tips I could probably shoot 20ft flames . I would like to get my car tuned for CO, as that should allow it to work pretty much anywhere else as I decided to live on the highest place on earth seemingly lol. I appreciate Chesbosto's work with the ECU. I think I will go with a SMT6 for a more "dynamic" solution for tuning, unless you guys offer 5600' elevation pre-tuned
Old Aug 13, 2003 | 07:55 PM
  #162
Chebosto's Avatar
Chebosto
Jason-
any plans for bone stock Z comparisons?
Old Aug 13, 2003 | 10:05 PM
  #163
Topics II's Avatar
Topics II
Originally posted by 2003z
$700? Not that there is anything wrong with that, but where's the outrage? People are complaining left and right about the cost of the technosquare.
if i can get 30+ rwhp and tq for under $700. I'll take 2!!!
Old Aug 13, 2003 | 10:06 PM
  #164
Topics II's Avatar
Topics II
But seriously, you can count me in for one tuned for 91 octane. And maybe one with a switch for 93 octane as well.
Old Aug 14, 2003 | 03:23 AM
  #165
j's350z's Avatar
j's350z
The cars that are in line for an install and dyno test are anywhere from bone stock all the way to ATI procharged. We were just taking our time on tuning my car so we have the perfect map to try in the other cars. We have been monitoring my car and are still making little changes(for the better) It looks like at least 2 units will ne installed tomorrow and dyno'd on Sat!!!
Old Aug 14, 2003 | 05:55 AM
  #166
Rxramon's Avatar
Rxramon
Charter Member #45
Cant wait to see the numbers!
I think Texas is a step behind compared to what ive seen come out Cali and East coast
Old Aug 14, 2003 | 08:48 AM
  #167
TOM Z CENTRAL's Avatar
TOM Z CENTRAL
Sir,Could we please stay with the subject & keep this Perfect Power ECU update going.I am intrested in results & feedback about the PB/ECU.Regards,Tom
Old Aug 14, 2003 | 11:03 AM
  #168
elektrik_juggernaut's Avatar
elektrik_juggernaut
As far as the Procharged Z, are you planning to try and eliminate the FMU with the SMT6?.......i was intending to eventually do this with my SAFC-II
Old Aug 14, 2003 | 12:59 PM
  #169
crustydemon's Avatar
crustydemon
JASON......
Installed tomorrow and Dyno'd Saturday????
Does this mean we will not have a baseline comparison, without the piggyback, on the test cars?
Old Aug 14, 2003 | 03:56 PM
  #170
j's350z's Avatar
j's350z
Yes we plan on using the SMT6 without the fmu that comes with the procharger. That also means that the people that order the procharger in the future, can order it in the tuner version without the fmu and just get our preprogrammed SMT6
And about the cars in line for the install, the beauty of this system is that you can plug in a bypass plug which turns the car back to stock. We hopefully will install a couple tomorrow and then Saturday when we get to the shop, install the bypass, dyno the baseline and then dyno again with the SMT6. I will also dyno my car again which has had it installed already for a couple of weeks. We are just trying to get the exact map that we want to release before installing it in the other cars, so hopefully we will be all set this weekend.....
Old Aug 14, 2003 | 04:02 PM
  #171
sschmuve's Avatar
sschmuve
I want to see a dyno of the SMT6 in combination with Crawford headers and Plenum, Injen SES, and Injen intake. Wouldn't this be about a 70 whp increase near redline?
Old Aug 14, 2003 | 06:18 PM
  #172
crustydemon
Sorry Jason...I'm sure this gets fustrating with the interogations, and I thank you for your responses.
I was curious about the ECU's optimization tasks.
I agree that the claims about the ECU detuning the car after installing mods is a MYTH. But the ECU does adjust certain paramters according to feedback from various sensors, and it's not instantaneous(as soon as you start up). I assume you have to run the car through the rpm range a number of times and for a period of time before the car builds an optimum map?
I speculated on Zcar.com that the lean numbers recorded on your base-run may have been the result of the car be tuned with the SMT6, and then being dyno'd too soon after removing the SMT6. I'm sure that, after bypassing, the ECU will not just simply default to the settings as they were before the install.
I know very little about the ECU, so first, is what I'm saying correct, or am I way off?
And, what is required(time/procedure) to return the car to it's original(optimized) map for the baseline dyno run?
Old Aug 14, 2003 | 06:40 PM
  #173
crustydemon
After reading my last post I realize I'm coming across as a nay-sayer, but in reality, I agree that there is more power available through timing.
We consistantly see better dyno numbers on consecutive runs from cars which remain unaltered through-out the runs. I assume this is the result of the ECU optimizing it's maps for the resistance of the dyno. This on-going optimization is what throws up flags when I hear you'll bypass the SMT6 for the baseline runs.
I am, truely, hoping for great results, but I guaranty these questions will come up after posting more dynos.
Old Aug 15, 2003 | 08:27 PM
  #174
350Z 2+2 ???'s Avatar
350Z 2+2 ???
Is it possible that the lean condition with the stock Z was causing some pinging resulting in the ECU pulling back timing? If this were the case, more power could be had by making the car run richer. I just had my stock G35 coupe dyno'ed today and my A/F ratios were no where near where this Z was. Here's a graph of HP and A/F.
Old Aug 15, 2003 | 08:29 PM
  #175
350Z 2+2 ???
Sorry, wrong pic!
Old Aug 15, 2003 | 09:08 PM
  #176
j's350z's Avatar
j's350z
I am not sure exactly what you mean if these are your dyno's. This car posted is running VERY lean, I think its even leaner than my Z was before the SMT6. Also, where did they weld in the o2 bung and wideband sensor?
Old Aug 15, 2003 | 09:13 PM
  #177
crustydemon
I wouldn't call a starting point at about 13.3/1 finishing at 11.2/1 LEAN. Maybe I'm reading the graph wrong.
Old Aug 15, 2003 | 09:19 PM
  #178
2003z's Avatar
2003z
Yeah, looks VERY rich to me too
Old Aug 15, 2003 | 09:21 PM
  #179
350Z 2+2 ???
I'm not sure if you are referring to my post or j's350z, but I was referring to the A/F ratios that j's350 posted earlier in this thread. Here's his link:
http://www.mrcmotorsportsllc.com/af.htm
The stock Z he used to tweak his ECU was running very lean... like 16:1 to 14:1 at redline. He made good power by fattening it up to around 13:1 across the board.
Old Aug 15, 2003 | 09:37 PM
  #180
JZC's Avatar
JZC
I'm in on the group buy if there is one.
Lemme see some dynos.
