Oil Psi
Old Aug 9, 2008 | 05:30 PM
ag4670's Avatar
ag4670
Unhappy Oil Psi
If anyone can help me trying to see if i got a problem with my engine i'm getting about 15psi after the cars fully warmed up I'm running m1 10w30
I'm pretty sure the gauge works cause once i punch it hits 100 and 60 crusining
Whats everyone psi after fully warmed up?
Old Aug 9, 2008 | 05:37 PM
surfcity40's Avatar
surfcity40
https://my350z.com/forum/search.php?searchid=6887021
lots of stuff here. have fun
Old Aug 9, 2008 | 10:33 PM
Hoooper's Avatar
Hoooper
^^^^ lol, link goes to page saying "no matches"
Old Aug 9, 2008 | 10:35 PM
Ruthless18x's Avatar
Ruthless18x
Your pressure is supposed to be a lot lower at idle. Granted that might be too low.
Old Aug 9, 2008 | 11:06 PM
gregom's Avatar
gregom
lol @ n00bs teaching n00bs.
15's pretty normal if you've been racing the engine... oil gets thinner due to the heat so when idling the pressure will be around 15. When its not been enjoying high revs and is up to normal operating temp it probably should be around 25. If it's 15 when you start your engine cold (sitting 3+ hours) then thats bad.
Old Aug 10, 2008 | 12:20 PM
WL350Z's Avatar
WL350Z
normal.
Old Aug 10, 2008 | 01:47 PM
ag4670's Avatar
ag4670
what about around 10psi after running it really hard?
Old Aug 10, 2008 | 03:21 PM
gregom's Avatar
gregom
It's normal mate... Oil is a lot like syrup, you know when you put syrup in the microwave to warm it up, then it gets really thin and runny... Oil is the same way. All the high speed movement of the internals cause friction and create heat, thus making the oil thin. Unless your pressure is like 1 or 3... or below 0 or something, you're fine. Oil gets thinner when it gets hot. Once it has cooled back to normal engine op temp it should be back to its 25-30 or so...
Old Aug 10, 2008 | 04:54 PM
gregom's Avatar
gregom
Turns out the pressure cant go below 0 on the readout. So if its at naught after you've been driving around then either there is a sensor problem or something is seriously phuqed with the engine.
Old Aug 11, 2008 | 03:12 AM
Axel's Avatar
Axel
You will especially get a low reading If you are using syn oil.
Old Aug 11, 2008 | 05:28 AM
rcdash's Avatar
rcdash
It depends on oil temp, oil weight/brand, rpms. My engine on Castrol 10W-40 would drop to mid teens. On Mobil1 15W-50/0W-40 mix never drops below 25...
Old Aug 11, 2008 | 07:04 AM
ag4670's Avatar
ag4670
sweet! man when i saw the oil psi look like it was gonna be at 0 i was like wtf is going on but i really appreciate everyone info
Old Aug 11, 2008 | 07:08 AM
JasonZ-YA's Avatar
JasonZ-YA
where in texas? aggie by chance?
Old Aug 11, 2008 | 01:50 PM
ag4670's Avatar
ag4670
I was the guy with the blue z and front bumper induction I went to one of your meets at twin peaks I was out there with my bro slammed is and friends itr
Old Aug 11, 2008 | 01:51 PM
ag4670's Avatar
ag4670
I was the guy with the tblue z and front bumper induction I went to one of your meets at twin peaks I was out there with my bro slammed is and friends itr
Old Aug 11, 2008 | 09:05 PM
gregom's Avatar
gregom
Why use 0W-40? lol...
Old Aug 11, 2008 | 09:07 PM
surfcity40's Avatar
surfcity40
aren't you a bright one.
Old Aug 11, 2008 | 09:09 PM
surfcity40's Avatar
surfcity40
How's that going for U?
Old Aug 11, 2008 | 09:17 PM
350zFreak05's Avatar
350zFreak05
is it normal for the for the pressure reading 90 when your hitting it and at crusing its like around 60 and idle it at around 30
Old Aug 16, 2008 | 11:46 PM
350zFreak05
no comments yet?
