Will an 07 08 motor fit an 03 Z
Old Aug 11, 2008 | 04:07 PM
350z 7k's Avatar
350z 7k
Smile Will an 07 08 motor fit an 03 Z
Is anything different.Since there two intakes on the 07 is it possible without any modification. 2 Swap
Old Aug 11, 2008 | 06:06 PM
doug's Avatar
doug
since the body is exactly the same dimensions.. of course it will fit
Old Aug 12, 2008 | 03:21 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Doug you left out just a few things.
Old Aug 12, 2008 | 03:22 PM
doug's Avatar
doug
he only wanted to know if it would fit
Old Aug 12, 2008 | 03:34 PM
L. Baggins's Avatar
L. Baggins
lol you guys are harsh
Old Aug 12, 2008 | 03:44 PM
superchargedg
Damn Noobs
We are not harsh at all........we just tell the truth.
Old Aug 12, 2008 | 04:07 PM
n1sm0r's Avatar
n1sm0r
lol... you guys are jokers
Old Aug 12, 2008 | 04:18 PM
godmans's Avatar
godmans
get the dual intake first, then you will learn more =)
Old Aug 13, 2008 | 09:41 AM
Done Deal DR's Avatar
Done Deal DR
+1!
It will fit (duh), but you will obviously need the 07+ hood unless you use custom mounts and place it way down in the chassis so you F up your oil pan and headers everyday. Other than that, the hardest part will be the electronics piece. This is my worst area, but definitely start with the proper 07+ ECU, but there will probably be a lot of headaches as there are extra pieces of electronics on the newer Z's that may cause conflicts if you aren't using an aftermarket ECU.
Old Aug 13, 2008 | 09:52 AM
Hoooper's Avatar
Hoooper
lol @ possible without any modification. just drop it in and plug everything back in. like putting a 383 in where a 350 used to be...
Old Aug 13, 2008 | 10:17 AM
4SHIZZIL's Avatar
4SHIZZIL
I like where you are going with this one....however I would wait for the piggy back ECU bugs to be worked out first. Do you know of any boosted HR's? There are only a handful and I am not one to be the "test dummy" with my ride. I see swaps being a big thing for twin turbo cars...not so much for the SC guys...
Why go through all that trouble when a built block 3.5-3.8 block is cheaper at this point?
Old Aug 13, 2008 | 12:24 PM
bbs350z's Avatar
bbs350z
why not just buy an 07+?? the amount of money and labor you put in, you could get f/i and be done with it
350z82
Oct 1, 2015 06:25 PM
