Stillen Supercharged
Old Sep 2, 2003 | 01:31 PM
  #61
tobydog's Avatar
tobydog
will the Stillen SC work for an Auto?
Old Sep 2, 2003 | 01:46 PM
  #62
skk100's Avatar
skk100
Stillen is currently working on a AT version. I think it might be almost ready. You might to call over there and ask.
Old Sep 2, 2003 | 06:39 PM
  #63
G3po's Avatar
G3po
Default Stillen
With as small as the default SC pulley appears, I would tend to agree with Stillen. In general you are limited to how much smaller a snout pulley you can be , due to belt slip and SC efficiency.
As the pulley shrinks there is less suface area for belt contact and hence a higher probablity for slip. Also spinning a smaller SC faster creates more heat than a larger SC being spun slower. As we know heat is bad , and increases the min octane requirements. It may be possible to increase the SC speed by increasing the size of tha crank pulley; however, it in turn would spin all the accessories that much faster as well.
Good headers and catback exhaust are allways good adders for any streetable SC application. Compared to the SC whine itslef , headers usually add an insignificant amount of noise. Little extra out tailpipe , some raspy sounds from the header itself (depending on the how thick the tube gauge).
Does Stillen provide:
a) larger injectors+ECU retune ?
b) inline FMU with stock injectors ?
c) Aux wet injector with piggyack controller ?
Generally b) is the most limiting but can easily work within CARB regs. c) can also be made to work within CARB and a) generally not.
350Z_Al
Oct 29, 2020 07:44 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
kyin
Oct 15, 2015 05:54 AM
Nicky R
Sep 20, 2015 01:05 PM
Calinismo350z
Sep 14, 2015 04:04 PM
