there are at least 5 poeple here with prchargers. I wanna see time slips
on
Judging by that a stock Z06 and the Procharger 350z make about the same rwhp and weigh about the same, the 350z has better gears though. A stock Z06 runs 0-60 in anyfrom 4.1 - 4.5 sec. amd 1/4 mile in 12.1 - 12.5, all depending on outside temp, it would be safe to say that the 350z procharged should run a little faster do to better gearing. like 0-60 3.9 - 4.4 and 1/4 mile 11.9 -12.4 with a good driver.
Z06 has a weight advantage and makes more torque, so I don't expect the times for the 350z to be any better. But I'm not a dragracer, and that's just my opinion. I might take my car to the local 1/8 strip just for giggles one time, but I'm sure somebody else will get to the strip before me.
on
I would be very surprised to see the Z run low 12's with the ATI. Especially since the suspension on this car is setup for roadcourse racing and not drag racing. My thought is that traction will be a problem for this car and kill its ET.
Originally posted by joust75
Thats why when you all get new wheels you have to make sure you get 10.5 rears and then slap some serious rubber on them!!!!!
The torque numbers for the Z w/ the procharger is around 280-290 at the wheels. Thats not enought torgue to get the 0-60 time up there with the Z06. A procharged Z is in the same HP class as a Z06, but the torque is what's gonna come into play when the vette is afew tenths of a second quicker to 60 and afew tenths faster in the 1/4. Trap speeds should be simillar tho.
on
well the only thing i am able to add to this is that greddy was able to pull a 12.7 1/4 mile with 334rwhp but it also has 339lbs of torque. that was with nittos 555r which are street tires. turbo magazine 0-60 was in 4.6. so i would guess even though procharger does not have the tourque like the greddy it does have more hp so it should have a higher trap speed and may do better because there will be a minimal on wheel spin compared to greddy off the line
11-09-2020 10:27 AM
