My clutch is acting weird...
Old Dec 16, 2008 | 07:29 PM
thomas'Z's Avatar
thomas'Z
Default My clutch is acting weird...
Ok so recently i was trying my MT Z to my friends house and i come up on a
stop sign so i push in the clutch to put into neutral then all of a sudden my
clutch pedal does a *Pop* sound and now is stuck all the way up against the
firewall. i can no longer get it into any gear after first, when i turn on the car
in neutral it will start but when i go to put it into first it is as if the clutch
pedal doesnt even exsist. so for the past 3-4 days i been Lifting the car up
and looking underneith it and have absolutly no clue what is up with it.
has any 1 had any simmilar problems, O yea and i cant drive it and its also 2
tow therefore i cant get it to a shop. thanks.
Old Dec 16, 2008 | 07:37 PM
Karenlee's Avatar
Karenlee
do a search....clutch slave cylinder?
Old Dec 16, 2008 | 07:55 PM
GooDy151's Avatar
GooDy151
what year is yours?
07 has recall on clutch slave.
call your Nissan dealer.
Old Dec 16, 2008 | 09:10 PM
go-fast's Avatar
go-fast
with a "pop" sounds like a clutch pivot ball (depending on year).hard to tell from here though,take a look underneath at the clutch fork.
Old Dec 17, 2008 | 06:48 AM
kramykram's Avatar
kramykram
any fluid leaking maybe your line popped
Old Dec 17, 2008 | 07:42 AM
t0mills's Avatar
t0mills
Clutch pivot bolt for sure. $8.60 from Nissan.
Went through this a while back.
Good luck.
-Tim
Old Dec 17, 2008 | 08:56 AM
thomas'Z's Avatar
thomas'Z
its an 04 and the brake/clutch fluid i keep puttin in is leaking,
my mechanic friend said to pour some in and pump the clutch and that should work but
im pumping it the fluid just keeps going past Min. and there is a little leak under the car.
so what does that say?
Old Dec 17, 2008 | 10:27 AM
t0mills's Avatar
t0mills
Well, you've obviously got a fluid leak.
The clutch system works off of that fluid.
Here's my take on what happened:
Your clutch pivot bolt broke. When that happens, there is nothing to hold the clutch fork inside the transmission. When the clutch pedal stuck to the floor, your instinct was to pry it back up and try pressing it again. By doing this, you are forcing more fluid into the slave, which is now over-extending and beginning to push the clutch fork out of the transmission.
As this happens, the rubber boot on the slave cylinder conveniently comes in contact with the sharp edge of the "skid" plate that surrounds it. The rubber boot is now torn, and that's where all of your clutch fluid is leaking from.
So, you now need that $8.60 bolt, as well as a slave cylinder, $40.00
Now, I could be completely wrong here, but the only way to find out is to get under your car, and see if you can wiggle the clutch fork around. You should almost be able to pull it right out of the tranny.
-Tim
Old Dec 17, 2008 | 01:40 PM
Clutch peddle sticks to the floor? Never heard of it.
Old Dec 17, 2008 | 03:52 PM
davidmcc's Avatar
davidmcc
I originally thought pivot ball when I read this too but it may just be your line. You're going to have to find out where it's leaking from anyway so you may as well go over the line and slave cylinder first. Have a friend push on the clutch while you watch for leaks if you have to. As mentioned before if you pull out on the clutch fork and it moves you need to replace the pivot ball. Here's a link to an upgraded aftermarket version. The bad news is that if it's broke you'll have to drop the tranny to install it.
Old Dec 17, 2008 | 04:37 PM
thomas'Z's Avatar
thomas'Z
ok thanks for the help, tomorrow im gonna raise it up again and get under it, as for today its raining like cats n dogs.....
but yea i pushed it and n pryed it out n pushed again so what ur sayin sounds Logical so as long as its only like a $70 fix or w.e im good but if i need to drop the tranny my z will be sittin in the street for a while...
Old Dec 17, 2008 | 04:38 PM
surfcity40's Avatar
surfcity40
how did you get the original post to post improperly?
Old Dec 17, 2008 | 04:39 PM
thomas'Z's Avatar
thomas'Z
huh?
Old Dec 17, 2008 | 04:48 PM
surfcity40's Avatar
surfcity40
Originally Posted by thomas'Z
huh?
nothing. it's just formatted wrong. must be firefox.
Old Dec 17, 2008 | 04:59 PM
surfcity40's Avatar
surfcity40
Old Dec 18, 2008 | 05:08 PM
thomas'Z's Avatar
thomas'Z
ok so it was the slave cylinder and something else forgot what the name was.
but my mechanic friend thats fixing the car says that something in the tranny is broken
now he has to Drop the tranny and its gettin towards christmas and money is getting
tight... so now on top of paying him just for parts i gotta add more cuz he needs to
drop the tranny. in thinkin this i barely bought my car maybe 3-4 months ago and
huntington beach ford assured me it was all good and we inspected it with our people.
shouldnt they pay for something they so called "checked". they are also suppose to pay
for a damage done by the previous owner and still havent. i dont know i could just be
mad and wanting some one to agree with me in this rage.. but thats what i think.
-Thomas
Old Dec 18, 2008 | 07:54 PM
go-fast's Avatar
go-fast
ha! clutch pivot ball!......do i win an internet prize?j/k
there is no way they could have forseen it's failure,chalk it up to used car bullsh$t that just happens.
Old Dec 18, 2008 | 08:00 PM
surfcity40's Avatar
surfcity40
they are also suppose to pay for a damage done by the previous owner and still havent. i dont know i could just be mad and wanting some one to agree with me in this rage.. but thats what i think.
-Thomas
Right there with you bro.
Old Dec 18, 2008 | 09:32 PM
matthew122's Avatar
matthew122
haha I think I was the only one that got this.
Old Dec 19, 2008 | 05:38 AM
t0mills's Avatar
t0mills
Not so fast, buddy. I called the pivot ball breaking, then taking out the slave cylinder.
-Tim
