How come when i shift
Old Feb 2, 2009 | 04:18 PM
Nicks93090's Avatar
Nicks93090
Default How come when i shift
how come when i shift does the gears sumtimes get stuck?
like usually going into 5th... ill push it to 5th but it gets stuck before going in and i think it goes in but it drops into neutral and my car revs up all the way???
is it cuz im being a ***** and not putting it in gear hard enuff or what ive dun it like 6 times.. is it suppost 2 b e sooo stiff
help pls
Old Feb 2, 2009 | 04:33 PM
IB Systems's Avatar
IB Systems
probably letting go of the clutch to soon...
Old Feb 2, 2009 | 04:34 PM
Squeaky350's Avatar
Squeaky350
^^^ what he said.
This trans is not like a honda civic or ford escort.
freedonutss's Avatar
freedonutss
350z have been known to be notchy and stiff. just put some muscle into it and youll be fine
Old Feb 2, 2009 | 05:20 PM
Zian's Avatar
Zian
Please ignore most of the inane posts about shoving it into gear. Give the synchros some time to do their job. If you are shifting correctly it should easily slide into gear. The two that said you are probably re engaging the clutch too soon may be correct...but whatever you do don't just slam it through. It is NOT an on off switch!
Old Feb 2, 2009 | 05:22 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
This may sound dumb, but move your seat up a little.
Old Feb 2, 2009 | 05:50 PM
Spork's Avatar
Spork
My gears shift smooth
Old Feb 2, 2009 | 06:12 PM
quietkilla6's Avatar
quietkilla6
Originally Posted by Spork
You're probably just weak as hell.
lmao
I think your just switching gears to fast, i had this problem at first. Just ease threw the gears dont slam threw them its hard on the syncros. Double clutch if you need.
Old Feb 2, 2009 | 08:32 PM
Nicks93090's Avatar
Nicks93090
yeah.. lol im strong and big enough for those who say go to the gym. i go twice a day 5 days a week anyways...
i feel that grinding noise.. and i feel like its breaking the car i dont want anything to happen 2 my baby hahah.
soo that grinding noise is bad it has 2 be.. but see when i rev out my car if it makes sense i can shift easy but if i shift at 2-4 000 rpm it gets stuck or its bumpy...
Old Feb 2, 2009 | 08:42 PM
kyx4n's Avatar
kyx4n
if its grinding that you havent pressed the clutch all the way.
are you sure the clutch is depressed all the way when you shift?
Old Feb 2, 2009 | 08:48 PM
fstrnldr's Avatar
fstrnldr
does it seem easier to engage the gears all the way w/ the car off? how does the clutch pedal feel? You could have a failing pressure plate, or hydraulic component that would cause the clutch not to disengage 100% and that will give you that issue. W/ a low post count, i'm assuming you just got the car, an easy way to tell if its just your driving style or something wrong would be to drive some other Zs or let someone else drive yours. Give us some more details on the car itself. Year, miles etc.
Old Feb 2, 2009 | 08:51 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
I thought that too until it started to grind and Nissan had to get me a new one.
Originally Posted by Nexx
ignoring the grinding noise, just shove it in there.
I do believe that our tranny's are crap.
Old Feb 3, 2009 | 05:06 AM
4SHIZZIL's Avatar
4SHIZZIL
Smile
Originally Posted by foreveryoung
Judging by your spelling,maybe you aren't smart enough to shift
and judging by your post count you are NOT smart enough to know any better or give advise!
sorry you started it...lol
the 300Hp (rev-up) cars did have a bad batch of tranny synchros... my buddy had one swapped out just a few weeks ago at the dealer for free.... he has a 2005 IP G like me... but my tranny is fine thus far.
OP
you problably need to hold the clutch.... also when you extend your arms the sterring wheel should be at your wrist. This is for racing, not everyday driving...put your seat up like TreeFiddyZee said.
Originally Posted by Fast n Furious 1
youre not double clutching like you should
Old Feb 3, 2009 | 05:14 AM
o2sys's Avatar
o2sys
i do find it harder to shift smoothly in my Z....i was more smooth with an awd manual car
Old Feb 3, 2009 | 07:08 AM
VO...'s Avatar
VO...
Administrator
help pls
Another scenerio might be that you need to change the tranny fluid. How many miles are on the car?
Old Feb 3, 2009 | 08:03 AM
2fast4comfort's Avatar
2fast4comfort
i have a real heavy oil in my tranny and i can tell you the temp outside within 5 degrees by how long it takes me to get it into 2nd or 5th gear(till the tranny warms up), just shift a little slower and you should be ok
Old Feb 3, 2009 | 12:32 PM
Nicks93090's Avatar
Nicks93090
My car is a 08
850 miles on it now i put them on it ib ought brand spankin new for 22
but anyways i dunno its not doing it today when i went driivng for a little..
it feels hard 2 engage a few gears and my clutch is all way in..
like my 1st gear 4th and 5th are like extra tuff to push the gear in.. so i dunno maybe i should get it checked also...
besides that..
should my Brakes squeeeeeek brandnew car..?
theve been squeeking since i bought the car right weni drove it off lot but i justh avnt given a thot to it..
Old Feb 3, 2009 | 01:51 PM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Could be an internal issue with the transmission or just not timing the shifts right with the clutch release. Either one is a strong possibility.
Old Feb 3, 2009 | 02:06 PM
Nicks93090's Avatar
Nicks93090
thx 4 the advise an help...
Old Feb 3, 2009 | 09:55 PM
pcharoe1's Avatar
pcharoe1
My car is a 08
besides that..
for the breakes I think you should be fine (performance breakes). The Z is a very noisy car.
Do you have brembos?
