smoking at WOT
Old Feb 7, 2009 | 07:08 PM
seZy350's Avatar
seZy350
Default smoking at WOT
did a little cruising last night, and as the title says, i was in 2nd gear and from 2000 to 5000 WOT i noticed alot of white smoke coming from the exhaust... what could this be? at normal driving everything seems fine.
Old Feb 7, 2009 | 08:06 PM
White smoke is indicative of coolant in the combustion chamber. But don't jump to conclusions. Bad fuel injectors will also cause white smoke.
Old Feb 8, 2009 | 05:45 AM
djamps's Avatar
djamps
Since it was night time and the exact color would be hard to tell, perhaps it could have been oil burning. You should check your compression and do a leakdown test if its low.
Old Feb 8, 2009 | 07:55 AM
terrasmak's Avatar
Can you only see it at night ???
Old Feb 8, 2009 | 10:50 AM
seZy350's Avatar
seZy350
daytime i can also see smoke coming out as well. only at WOT though.
Old Feb 10, 2009 | 08:07 PM
TheFarmer's Avatar
TheFarmer
Could be some condensation left in the exhaust vaporizing? Was it cold out? A lot of white smoke usually means coolant in combustion chamber. If it's just a puff when you gun it, not a big deal.
Old Feb 11, 2009 | 10:20 AM
andypandy's Avatar
andypandy
I was gonna say... sniff the tailpipe. Then I realized it's only at WOT.
Perhaps someone can rev WOT while you sniff the tailpipe? LOL...
On a serious note, a slightly sweet smell indicates coolant combustion. A small whiff directed by hand is a good test.
Old Feb 11, 2009 | 11:22 AM
rcdash's Avatar
rcdash
Most likely clogged PCV leading to elevated crankcase pressure and oil being evacuated through the motor - exhaust - voila, smoke. $16 part - 5 mins - swap it out.
Old Feb 22, 2009 | 07:35 PM
seZy350's Avatar
seZy350
changed the pcv and its still smoking =[
Old Feb 22, 2009 | 08:43 PM
SchismX's Avatar
SchismX
As mentioned, do a compression and leakdown test.
Chris350z03
Oct 8, 2023 07:19 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
FromGtoZ
Sep 20, 2015 03:41 PM
pdexta
Sep 14, 2015 11:27 AM
Bigsyke
Sep 11, 2015 06:19 PM
