06 Clutch Pedal Stick
Old Mar 5, 2009 | 01:07 PM
spontaneous429's Avatar
spontaneous429
Default 06 Clutch Pedal Stick
i need some help diagnosing a problem that just started today with my 06 Z. Everything has been driving fine, just rolled over 40,000 miles. On my way back from lunch today my clutch pedal began to fail to return after a shift. It's shifting fine, and engaging fine, but right after i pull back off the 'spot' is where it's getting stuck... about an inch to go. any ideas? It feels almost just like a grease or lubricant issue? Thanks.
Old Mar 5, 2009 | 02:10 PM
freedonutss's Avatar
freedonutss
Im assuming you still have the drivetrain warranty? Take it to the dealer.
Old Mar 5, 2009 | 02:44 PM
josesantigo57's Avatar
josesantigo57
I have that same problem, but mine is heavily modded and hits the track every month. I just pop the clutch a couple times and it goes away, with the car in neutral of course.
Old Mar 5, 2009 | 02:54 PM
ish06FairladyZ's Avatar
ish06FairladyZ
mine does that only on hot days during summer but other than that it's never been an issue...
Old Mar 5, 2009 | 03:44 PM
psherwin's Avatar
psherwin
Dude...I have an 06' and experienced this same issue for the first time today after getting off of the highway. I was lifting that clutch off of the floor the rest of the way home. I'm doing the same as you...searching around forums for a solution. I checked the master and slave and there are no leaks on mine. -Phil
Old Mar 6, 2009 | 12:49 AM
kramykram's Avatar
kramykram
you may not have leaks. but if your clutchline is giving out, it could cause the problem. if it is doing it while the car is hot, it is most probably the line.
Old Mar 6, 2009 | 06:46 AM
spontaneous429
well after my initial posting yesterday afternoon, I drove home... no problems. I stopped at nissan on the way home to ask them about it, and they basically told me it'd be $98 for a straight answer. F' those guys. I'm going to wait to see if it comes back and go from there. Sounds like i'll probably have to get some work done on it before too long, but i'm going to wait as long as possible. I might even get down there this weekend and try lubing some of the pedal pivots. I appreciate the replies.
Old Mar 7, 2009 | 08:58 AM
kramykram's Avatar
kramykram
i would go with the clutch line. its cheap and easy to replace if you have basic mechanical skills.
Old Mar 9, 2009 | 08:06 AM
SK350z's Avatar
SK350z
yeah f those nissan dealers!!
Old Mar 9, 2009 | 08:08 AM
SK350z's Avatar
SK350z
i'm having the same problem with the clutch sinkin in, it happens once in a little while. If anyone finds the answer PM me plz! I am also trying other sources to figure this out. One said to replace the clutch.. dam..
Old Mar 10, 2009 | 11:12 AM
cheshirecat79's Avatar
cheshirecat79
Replacing the clutch line with a stainless steel one and flushing the line out with some DOT4 fluid is the way to go if your master and slave cylinders aren't in need of replacement.
btw, search people.
Old Mar 14, 2009 | 04:03 PM
jesse&alaina's Avatar
jesse&alaina
I had sme problem problem speicali a the track changed to ss line and changed to a hotter fuild no more problems
Old Mar 15, 2009 | 02:51 PM
spinviper's Avatar
spinviper
I have the same problems + the car smell weird like something burn.
Oh and it shows VDC off and SLIP sign on sometime.
Mine is 2006 Track Manual
Anyone have solution for this ?
Old Mar 16, 2009 | 09:35 AM
Sasha350's Avatar
Sasha350
Same thing happened to me on my 06, pushed teh clutch in and it failed to return. usualy it would happen after some driving, not right away..
So anyway, I bled the clutch really well and no more problems...suggest you try the same...good luck
Old Mar 20, 2009 | 02:19 AM
spinviper's Avatar
spinviper
waiting 4 answers
Old May 8, 2009 | 08:23 AM
muflon's Avatar
muflon
Default +1
+1 04 Base, same symptoms. Clutch sticks when revving up to high RPMs and releasing the pedal. VERY strong burning smell.
Here is another similar thread
http://forums.nicoclub.com/zerothread/119373
Is it normal to have a burning smell outside of the car after riding the clutch just a little bit (like going up hill or stop and go traffic) or is it a sign of the clutch failing soon?
I've owned 6spd cars all my life and never had any problems like that...
Old May 8, 2009 | 11:03 AM
pony_killer's Avatar
pony_killer
Arada ninda apa
master cylinder problem...i had that issue last week took it to the dealer this week and they said they have to replace the master cylinder (under warranty)...should be here next week.
Old May 8, 2009 | 01:01 PM
Gingervitis526's Avatar
Gingervitis526
http://www.rangeracceleration.com/Clutch_Care.html
That should tell you everything you need to know, watch the video.
Old May 12, 2009 | 07:52 PM
NissanDrifter06's Avatar
NissanDrifter06
btw, search people.
thats what i did for mine. i replaced the slave cylinder and clutch line to stainless steel and ran dot 4 fluid. but sometimes i still have my clutch pedal sticking. seems like theres still air pockets in my lines somewhere...
i even put back on the factory clutch line heat shield wrap on my stainless steel to have that extra help.
Old May 13, 2009 | 02:54 AM
Fairlady_z33's Avatar
Fairlady_z33
First thing you have to do is check the master and the slave for any leaks if they r good to go then move on to the clutch line and fluid. Dirty fluid can sometimes cause this symptoms as it may have accumulated moisture and once it heats up it evaporates and it air appears from the moisture been evaporated.
Just upgrade to a SS clutch line heat rap it and get some motul 600 racing fluid is like 15 to 20 bucks. On stock clutches that should do the trick. I have this issue but I have a carbonetics triple disc. Hope this helps and if I made any incorrect statement then please correct me.
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
