clutch recomendations
on
In the process of installing a new clutch and don't want the OEM unit. Been away from z's for 10 years and don't know what is current. Been doing some research and I am thinking about the JWT HD clutch kit. JWT lightweight flywheel , IPP chromoly clutch pivot ball , IPP ss clutch line , and the Nismo roller bearing pilot bushing. Can you give me a recomendation or am I on the right track.
on
Will do more searching on it. Clutch needs changing so I thought I would do it now. Going to have SGP in Houston build a motor next month I havent decided how far to take it yet ,
on
Like eltness350 already mentioned, it really does depend on what you're trying to put to the ground. For a stock Z the JWT combo is great, that's what I'm currently using and I like it so far. I do however plan on running something else once I go FI.
...and IMHO the Nismo roller bearing pilot bushing is a complete waste of money. Granted it's only like $10, I wouldn't bother unless it was included in some type of package deal.
Vendor - Former Vendor
It really all depends on what you have planned for your build. If you're going boosted in the future plan for that and get a stronger clutch than you need at the moment. We're running our new Street Performance clutch in our company G35 coupe and it's been flawless. Stock-like pedal and engagement and it's been beaten on at the track a couple of times already as well. That is what we push for N/A cars but would never put it in a F/I car.
The Untouchable
on
+1 ...i run a clutchmasters stage 4 clutch alum. flywheel....lil harder then stock engagement and will hold a bunch of powa....great clutch till u go f1 and will hold when u decide on ur route...unless u wanna shell out a bunch of coin for multiple discs...
on
I just had the JWT HD clutch kit, JWT lightweight flywheel, chromoly clutch pivot ball , SS clutch line , and the Nismo roller bearing pilot bushing (all came together in a package). A great deal at that.
The JWT clutch feels much much heavier in regards to pedal feel. Engagement is flawless however. Acceleration rev up is noticeable as is downshifting in that the lighter flywheel spools up and down quicker. Definitely does not feel anything close to stock. I like how the car behaves with it though so I'll just get used to the heavier feel. Hope that helps...
Where did you purchase this kit?
That's exactly where I got it. You're right in that customer service is second to none with this place. I think it was Kyle that I had dealt with.
11-09-2020 10:27 AM
