clutch/flywheel noise?
Old Apr 5, 2009 | 02:40 PM
sina518's Avatar
sina518
Default clutch/flywheel noise?
okay so i have searched to see if any one else has this problem and all i can find is flywheel chatter at a complete stop. i had a competion clutch and flywheel installed today (stage 2) and it drives fine and engages and disengages like it should but when i start off slow in first or 2nd and even in reverse i hear noises coming from the trany. is this normal because i have a lighter flywheel??? all help will be appreciated.
Old Apr 5, 2009 | 03:22 PM
Don't see how a flywheel-clutch combination would effect the transmission. Sorry.
Old Apr 5, 2009 | 03:38 PM
sina518's Avatar
sina518
i dont mean the trany itself making noise. but when i engage at a low rpm it makes noises from the clutch area.
Old Apr 5, 2009 | 03:45 PM
3FITTTY's Avatar
3FITTTY
does it sound like a dump truck?
Old Apr 5, 2009 | 03:53 PM
sina518's Avatar
sina518
pretty much
Old Apr 5, 2009 | 03:56 PM
davidmcc's Avatar
davidmcc
This is absolutely normal. The noise associated with lightweight flywheels, and often mistaken for clutch chatter actually comes from the transmission. The stock dual-mass flywheel is designed to absorb these noises. When you switch to a lightweight flywheel you lose that muffling effect and the rattling sound produced by the transmission becomes audible.
Old Apr 5, 2009 | 04:02 PM
sina518's Avatar
sina518
okay cool that's what i thought. thank you very much.
Old Apr 5, 2009 | 06:24 PM
After market flywheel-clutch makes all sorts of strange noises. It might sound like a cement mixer. You get used to it.
Old Apr 6, 2009 | 09:49 AM
corder84's Avatar
corder84
I bought my car used so i dunno if my clutch and flywheel is stock or not...but i have chatter in 1st gear unless i rev the car a little more then take off. You guys have any ideas on mine??
Old Apr 6, 2009 | 12:09 PM
davidmcc's Avatar
davidmcc
Depends, do you have actual clutch chatter or just a rattling sound? ...there is a difference.
This is clutch chatter:
http://www.youtube.com/watch?v=dPIZFugC2P8
That can be caused by a lot of things such as an uneven surface on the clutch or flywheel and isn't exclusive to just aftermarket clutch/flywheel combos. If it's just the rattling sound I'd lean more towards there being an aftermarket unit installed.
There is a little cover on the bottom where your engine and tranny meet, if you remove that (just one bolt holds it on) you may be able to get enough of a peak inside to determine if you have an aftermarket flywheel.
Old Apr 6, 2009 | 08:44 PM
leg killa's Avatar
leg killa
lol...most people are aware of the chatter before installing different flywheels....some are cool with it while some hate it...JWT is notorious for have loud "chatter"...i run a ACT set up...it does chatter but barely..atleast to me..it dont bother me..some clame that their exhaust would drone it...idk its all on you
Old Apr 6, 2009 | 10:48 PM
marra23's Avatar
marra23
my act prolites a chatterbox at low rpm. i did notice some noise at idling which goes away when engaging the clutch....recon its my throw out bearing
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
