18G's.......How much boost?
Old Oct 1, 2003 | 12:21 PM
kudos's Avatar
kudos
Default 18G's.......How much boost?
Just wondering if anyone has any idea on how much boost the greddy TD05/18G's can make max.
Old Oct 1, 2003 | 01:04 PM
kurt leonce's Avatar
kurt leonce
about 25-28# of boost, i think, i know it is not under 25#
Old Oct 1, 2003 | 01:44 PM
Ricky's Avatar
Ricky
But won't worry, you won't be able to crank it up half as high as that without some serious engine work!
Old Oct 1, 2003 | 02:00 PM
kudos's Avatar
kudos
Actually i am worrying ALOT, because my car is getting alot of engine work as we type.....lol
Old Oct 1, 2003 | 02:28 PM
Landbarger's Avatar
Landbarger
That's certainly a statement that could raise a few eyebrows.
Old Oct 1, 2003 | 02:40 PM
kurt leonce
why not have a custom kit made at the same time, with better turbo that 18G,
Old Oct 1, 2003 | 02:58 PM
kudos's Avatar
kudos
It would be more expensive, the reason i was asking was that if the 18G's didn't produce enough boost then i would have to figure out a way to replace the ones supplied with greddy kit and put slighty larger turbos.
Old Oct 1, 2003 | 05:31 PM
spazpilot's Avatar
spazpilot
18g turbos are good for 450hp each. so that means you would have to build a 900+rwhp monster. boost they are good for up to 35psi
Old Oct 1, 2003 | 07:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'd love to see an 18G at 35 psi....talk about off the efficiency chart (considering the 18G is not the most efficient compressor side to begin with).
16G's would have been a much better choice for the car IMHO....
Old Oct 1, 2003 | 08:19 PM
kurt leonce
the only bad thing about the 16g, is that each one is only good 300whp- 350whp, and being that he has engine work done to the engine the 18g will be alot better for the long run, no need to upgrade turbos when he has reach 700whp and wants more, it happens all the time people get small turbos for quick spool up but lose when more power is needed, as for the turbos greddy is using they are TD05H 18G flows better than TD05 18G. its your money spend it how you want to
its up to you, every turbo has is limits
Old Oct 1, 2003 | 08:25 PM
kurt leonce
I don't have you every seen a turbin wheel twisted off the shaft and of come fly out the ex. well i have and the 18g will do just that at 35 psi
Old Oct 1, 2003 | 11:25 PM
spazpilot's Avatar
spazpilot
kurt leonce
Had an 18g on my turbo eclipse. never did it to me. anyways don't think he will need that much boost for the car
Old Oct 2, 2003 | 08:28 AM
kudos's Avatar
kudos
As long as the will do anything close to 27psi effeciently then i'm more than happy.l
Old Oct 2, 2003 | 08:48 AM
kurt leonce
with external wastegate the 18g should be ok, why so much boost, hope you build the hole bottom and head of the engine, APR bolts is a must for so much boost. but i will love to see 27psi on a Z that baby is going to fly.
have an eclipse to witha T3T4 at 25# of boost that **** is fast , never dyno
Old Oct 2, 2003 | 09:19 AM
kudos's Avatar
kudos
Trust me man, i'm not leaving anything untouched. Actually i'm planning on making it fly for the longest time possible.
Looks like i'm gonna keep the turbos that come with the greddy kit wich is good news, i just hope it's out by the time my motor is done.
Old Oct 2, 2003 | 09:34 AM
Rxramon's Avatar
Rxramon
Charter Member #45
Do you guys run JSPEC or USSPEC in Qatar?
Old Oct 2, 2003 | 01:24 PM
kudos's Avatar
kudos
Actually i bought my car from austin and the car is in houston at the moment.
But in qatar we haven't got the Z's officially yet, we might next year and if we do then we would get the middle eastern spec car.
Old Oct 3, 2003 | 09:16 PM
1DeepG's Avatar
1DeepG
I have an 18g on my turbo civic right now. The turbos max efficiency is around 18psi. After that you are just blowing hotter air into the car. Hopefully you are using external wastegate(s). I would have to agree with adam on this one, you are going way off the efficiency charts if above 20psi. If you are building up yor engine, might as spend some more and get some better turbos if you are going to be pushing that much power. Garett GT Series or Presicion(sp?) turbos.
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
