OS Giken Triple Disc, 1st gear, i must be doing it wrong
Old Jul 28, 2009 | 02:16 PM
Nexx's Avatar
Nexx
Default OS Giken Triple Disc, 1st gear, i must be doing it wrong
Good God, I feel like such a newb. I cant drive my car anymore. 1st gear after my OS Giken triple disc install is even more a ***** then my 6 puck stage 4 competition clutch. what am i doing wrong?!!? there is virtually no way to slip the clutch, its either engaged or it isnt. im either stalling or burning out off the line. help!!! lulz.
Old Jul 28, 2009 | 05:25 PM
6speedwonder's Avatar
6speedwonder
thats pretty much whats going to happen, learn to love it lol :-)
Old Jul 28, 2009 | 05:36 PM
djamps's Avatar
djamps
More revs. I know it sucks, and people think you can't drive a stick.
Old Jul 28, 2009 | 05:41 PM
03threefiftyz's Avatar
03threefiftyz
Takes a few weeks........I raised my idle to help compensate. There does seem to be a bit more slip and far less shuttering now after ~600 miles. The first 200 miles it was on or off. I would have to imagine the triple is even worse, but it should "loosen" (not sure that is a good choice of words) up a bit.
Old Jul 28, 2009 | 06:00 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Old Jul 28, 2009 | 06:32 PM
Nexx's Avatar
Nexx
Originally Posted by Chef-J
lol pretty much.
sigh. on a side note, the rest of the gears are like butta.
Old Jul 28, 2009 | 06:37 PM
03threefiftyz
Have you driven or owned a car with an integrated set-up before? It's much standard to have no play or slip in em.
Old Jul 28, 2009 | 06:40 PM
Nexx's Avatar
Nexx
nope, but my last setup kinda prepared me for this. the comp stage 4, 6 puck was very similar in first gear. ive been trying to baby the car off the line for break in. i was hoping to avoid more revs if possible to get her going but stalling sux so more revs it is. i just hope this clutch can handle the 5000rpm launch at the track unlike the the comp stage 4 that just got destroyed.
Old Jul 28, 2009 | 06:43 PM
03threefiftyz
what power level......the triple should hold 650-700wtq without too much issue.
Old Jul 28, 2009 | 06:47 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Should hold without problem. If it fails.......you might have to look for driving school. j/k
Old Jul 28, 2009 | 06:50 PM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
wooooo! triple disc! try blipping the throttle and as the revs come down release the clutch slowly and give it a bit more gas. works out great! takes alot of the shuddering out.
Old Jul 28, 2009 | 06:53 PM
03threefiftyz
The first time you feel that shudder.......you think all 4 wheels are going to fly off the car, but you get used to it and learn to get moving without it.
Old Jul 29, 2009 | 09:36 PM
Chomorro's Avatar
Chomorro
Interesting, my single disc has a little slip to it but its still on or off. I have to rev it a little higher to get a smoother engagement.
Anyways its interesting because the double and triple disc are supposed to be easier to daily drive according to GTM.
Old Jul 29, 2009 | 09:53 PM
03threefiftyz
That's how mine is, but you have about ~1-1.5cm of play before it stalls. It is still much easier to drive than the tilton twin I had in my previous car. As long as I give it 1500-1700 rpm from a stop or catch it on the down rev around that point all is fine.
Old Jul 29, 2009 | 10:23 PM
yeZir's Avatar
yeZir
Maybe pulling off in 2nd? i know a lot of drivers here in Korea do it all the time, especially bus drivers. i know it sounds stupid, just suggesting based observation......i have flame suit on standby just in case.
Old Jul 29, 2009 | 10:37 PM
03threefiftyz
These clutches have no slip.......trying to go in 2nd would result in nearly immediate stall. Even if you could get it to slip enough it would be overly stressful on an expensive clutch. I wouldn't do it on my OS that's for sure. After a week he will have the hang of it.
Old Jul 30, 2009 | 05:21 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Beat me to it
Just do some practicing in a parking lot - it takes a bit of attention, but after you spend some time, you'll get the hang of it. You want to blip the throttle up to around 1500 or so, and then as it swings downward to ~1000, begin letting the clutch out and feeding it very light throttle. Like I said takes a bit of practice at first, but it becomes second nature pretty quickly.
Pulling in 2nd requires even more revs - I've done it, it works fine, but it's just more slip. I wouldn't bother with it.
Old Jul 30, 2009 | 05:23 AM
Z1 Performance
Former Sponsor
Beat me to it
Pulling in 2nd requires even more revs - I've done it, it works fine, but it's just more slip. I wouldn't bother with it. Hell, I had to start the car in 3rd from a dead stop on a 15 minute drive home (when the nut for the shift lever came out and the shifter came out of it's notch - though the trans was still in 3rd gear) - caused alot of slipping but the clutch took it. But, why intentionally wear it that way if you don't have to
Old Jul 30, 2009 | 07:04 AM
Jtran Studios
carbonetics triple isnt as bad to drive from what ive driven. os giken is what kills me to drive.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
