Finally building short block. Need opinions.
Old Aug 9, 2009 | 01:38 PM
mtm864's Avatar
mtm864
Default Finally building short block. Need opinions.
Hi Guys,
I'm finally building up my short block. I am looking for suggestions and opinions on what i have planned out so far. Im kinda on a budget but i want good stuff as i will be going FI or Nitrous soon after break in.
Non Sleeved VQ35DE Non Rev-up Block
bc rods BRODS pn:BC6229
Wiseco 8.8:1 pistons
Cometic Multi layer steel headgasket
ARP L19 head +main stud kit
Cosworth Tri-Metal Race Bearings (rod+mains)
Revup oil pump
My main concerns are:
-Are the Wiseco's a good choice for a street car or shoud I go CP's or Arias? Is the compression ratio a good choice for 550 - 600rwhp with a APS TT kit, greddy tt kit or spray.
-Whats a good engine management and fuel setup for DD with this car and setup
-Clutch which one and what kind?
Sorry for all the questions guys but I want to do it right and do it once. Thanks
Old Aug 9, 2009 | 02:45 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Why not just buy forged's S1 block? they are not far from you.
http://www.forgedperformance.com/sto...4&cat=0&page=1
Old Aug 9, 2009 | 05:49 PM
mtm864's Avatar
mtm864
I dont know lol. Just like the fact of building my own motor i guess im just weird like that. I found the rods i will be going with. They are the bc brods anyone one here using these?
Old Aug 9, 2009 | 06:27 PM
eltness350's Avatar
eltness350
The Untouchable
use the eagle rods....they will handle the same amount of abuse and cheaper.... +1 on buyin a shortblock ready to go...
Old Aug 9, 2009 | 06:51 PM
mtm864's Avatar
mtm864
thanks man eagle it will be!
Old Aug 9, 2009 | 08:02 PM
rcdash's Avatar
rcdash
+1 on the forged S1 shortblock. Very good set up, tried and true up to some 800+ whp I believe. I think you can substitute parts if you really want to (and maybe save a few bucks), but I wouldn't.
Old Aug 9, 2009 | 08:38 PM
vthao's Avatar
vthao
Wiseco's are tested and true. Good choice.
Uprev Osiris!
JWT clutch
Old Aug 10, 2009 | 04:09 AM
Quamen's Avatar
Quamen
My vote would be Arias pistons and Eagle rods.
Old Aug 10, 2009 | 04:38 PM
eltness350's Avatar
eltness350
The Untouchable
jwt clutch might not be strong enough to hold 550-600hp like u r goin with...i would suggest a twin disc or an extreme single like clutchmasters stage 4(i have) to hold all that powa
arias pistons 9:1 comp ftw
Old Aug 10, 2009 | 06:40 PM
mtm864's Avatar
mtm864
how are you liking the engagement on the cm stg4??
Old Aug 10, 2009 | 07:02 PM
eltness350's Avatar
eltness350
The Untouchable
a little noisy but u will def have that with a lightweight flywheel and aftermarket clutch...30% harder pedal pressure then stock imo
Old Aug 11, 2009 | 08:09 AM
zerosec's Avatar
zerosec
i have MAHLE pistons , but wiseco are gr8 too !
as for the tune, UPREV FTW !
Old Aug 11, 2009 | 03:52 PM
zman1982's Avatar
zman1982
Z1 Motorsports shortblock is a good package as well.
Old Aug 11, 2009 | 07:39 PM
mtm864's Avatar
mtm864
thanks guys i think im going wiesco 11:0:1 and not boosting. Leaning toward spray the cheaper route. Any suggestions on a spray motor
Old Aug 12, 2009 | 05:45 AM
str8dum1's Avatar
str8dum1
I'd run a 9:1 compression with a dual stage 250 shot.
Old Aug 12, 2009 | 06:12 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I would use Arias ED's, Eagle Rods, L19 head studs for most builds. If you want to build it yourself, we can supply you every single part needed to put the block together. Just let us know.
Old Aug 12, 2009 | 11:56 AM
mtm864's Avatar
mtm864
Thanks i will contacting you shortly
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
