Help after VLSD swap
Old Aug 12, 2009 | 11:34 AM
riverrat0341's Avatar
riverrat0341
Default Help after VLSD swap
Ok, have a base model 05 Z. Changed the pumpkins and after driving about 1 mile down the road the ABS light comes on. Is this because I went from an open diff to the VLSD. Has anyone else had this problem. Fix?
Old Aug 12, 2009 | 11:55 AM
rookie's Avatar
rookie
Should not set off anything just from changing. Did you bolt the sensors back on?
Old Aug 12, 2009 | 12:51 PM
riverrat0341
yes and checked wiring.....????
Old Aug 12, 2009 | 01:01 PM
rookie's Avatar
rookie
As long as the sensor harness is plugged in it should be fine. It's clipped in place pretty well so there isn't much chance of it rubbing on the output shafts. But check to make sure nothing got chewed up.
Old Aug 12, 2009 | 01:03 PM
riverrat0341
alright. I'll jack it back up this weekend. Gotta work next 2 days. I'll let ya know though. Thanks for the help
Old Aug 19, 2009 | 09:03 PM
ohyea's Avatar
ohyea
did you figure it out yet? What are you going to do with your open diff?
Old Aug 21, 2009 | 03:38 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Check the speed sensors which point directly to the stub axles reluctor wheel. I bet one of them is loose, messed up, or unplugged.
Old Aug 31, 2009 | 05:28 AM
riverrat0341
I have the open diff if anyone wants it. Will be posting it once I can take a pic with my name in it a and all. 200 shipped.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
SpartanZ32
Oct 22, 2015 09:36 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
SharX59
Sep 27, 2015 09:23 AM
